A Engine Offset Cam Keys? #2463421
03/08/18 11:17 PM
03/08/18 11:17 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Who is selling the offset cam keys today? It looks like the MP P4286500 key set has been canceled.
Re: A Engine Offset Cam Keys? [Re: rarefish] #2463425
03/08/18 11:26 PM
03/08/18 11:26 PM
I want another set & could not find em. I would suggest a 3 keyway timing chain set of the quality level that you want. Other than that: ebay or CL or maybe another mopar site (FABO wanted might be good).
Re: A Engine Offset Cam Keys? [Re: rarefish] #2463427
03/08/18 11:29 PM
03/08/18 11:29 PM
P
Porter67 Offline
Porter67  Offline
P
They pop up on ebay from time to time, but they are like $50 for the set of 4.
Ive three loose ones I dont need if you know what color you need, Id have to look but I think ive a blue, a brown and a yellow.
Re: A Engine Offset Cam Keys? [Re: rarefish] #2463437
03/08/18 11:44 PM
03/08/18 11:44 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
I have a few of them right now, but a friend called me tonight looking for a 4 deg key. Does anyone know what color that key is?
Re: A Engine Offset Cam Keys? [Re: rarefish] #2463443
03/08/18 11:53 PM
03/08/18 11:53 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have the info in the shop. but it'll be tomorrow before I'll be back out there.
When I built my 408 I needed one that I didn't have and a member sent me one at no charge. A few months later someone here needed one that I did have so I returned the favor that was given to me.
I did later buy a set off the bag.
Re: A Engine Offset Cam Keys? [Re: rarefish] #2463463
03/09/18 12:32 AM
03/09/18 12:32 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I have a Mr Gasket one I got from Summit about a year and a half ago. I don't remember the PN. It took months to actually receive it. Good thing I was in no hurry for it. I already had a timing set in my parts pile or otherwise I would have just bought a multi-keyway set instead. I believe the MG key is 4 CAM degrees; i.e. 8 CRANK degrees. I degreed the cam twice with the offset key to make sure I hadn't screwed up and came up with approx 8 degrees more than the straight key both times.
Re: A Engine Offset Cam Keys? [Re: forphorty] #2463477
03/09/18 12:40 AM
03/09/18 12:40 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Summit stocks any key you should need. I buy all of mine there.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: A Engine Offset Cam Keys? [Re: pittsburghracer] #2463518
03/09/18 01:40 AM
03/09/18 01:40 AM
I only see the "round" BB ones at Summit. the SB ones sorta look like a cam key with the top half of it "shifted/offset" over which shifts the cam gear.
Re: A Engine Offset Cam Keys? [Re: pittsburghracer] #2463519
03/09/18 01:42 AM
03/09/18 01:42 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I couldn't find any key for a B/RB other than the 0 degree.
Re: A Engine Offset Cam Keys? [Re: 6PakBee] #2463531
03/09/18 02:05 AM
03/09/18 02:05 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Hughes Engines is showing the 4 deg offset key on their website.
http://www.hughesengines.com/Index/products.php?browse=search&search=CAM+KEY&partid=26066
Re: A Engine Offset Cam Keys? [Re: Neil] #2463579
03/09/18 05:37 AM
03/09/18 05:37 AM
The LA motors and all early(pre 1965) non B/RB and 426 hemi V8 Mopars used the same upper cam keys, including the Chrysler Fire power and Desoto Fire Dome hemi motors work
Mr. Gasket sold them in the past, maybe Hot Heads has them still scope
Re: A Engine Offset Cam Keys? [Re: rarefish] #2463601
03/09/18 10:17 AM
03/09/18 10:17 AM
Sullivan, IN
Mopar Sam Offline
Mopar Sam  Offline
Sullivan, IN
The Mr. Gasket ones are sometimes listed as small block chevy crankshaft keys.
Re: A Engine Offset Cam Keys? [Re: Mopar Sam] #2463741
03/09/18 02:29 PM
03/09/18 02:29 PM
Your probably correct on that up bow
Re: A Engine Offset Cam Keys? [Re: rarefish] #2463775
03/09/18 03:16 PM
03/09/18 03:16 PM
P
Porter67 Offline
Porter67  Offline
P
Looks like so far ive got a yellow and a blue, I dont recall doing it but I must of as the blue is marked 3 and the yellow 4.
If you can use them pm me your addy and I will toss them in a envelope.
I still think ive one more, like a brown one.
Re: A Engine Offset Cam Keys? [Re: Porter67] #2463848
03/09/18 05:00 PM
03/09/18 05:00 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My noted indicate the same, yellow is 4°.
Re: A Engine Offset Cam Keys? [Re: justinp61] #2464031
03/09/18 09:36 PM
03/09/18 09:36 PM
PA.
"Little"John
"Little"John
PA.
Thanks a lot guys you jinxed me. I'm putting my 572 together today and throw the timing cover on and want to install my ATI damper on to check my timing marks before I install the heads this weekend. Well my machinist must have removed my key to do his work and it didn't get reinstalled. Usually not an issue but this is a Calias crank with a 1/4 inch keyway instead of a 3/16 so it uses a 1/4-3/16 stepped key. I have over 20 keys here but of coarse no stepped keys so I found one on Summits site for 18.00 and it should be here Monday or Tuesday. Oh well I guess I will be building the transmission for it instead. LOL
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: A Engine Offset Cam Keys? [Re: rarefish] #2464035
03/09/18 09:39 PM
03/09/18 09:39 PM
P
Porter67 Offline
Porter67  Offline
P
Just marry two unrelated keys and poof you will a have step key. Like step kids.
Ok, not funny.
Re: A Engine Offset Cam Keys? [Re: Mopar Sam] #2465721
03/13/18 12:47 PM
03/13/18 12:47 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
I used this one, just remember its the camshaft you are moving, not the crank like this one is made for. If you want 4 degrees advance, get a 2 degree key.
Re: A Engine Offset Cam Keys? [Re: gtsdude] #2465821
03/13/18 03:37 PM
03/13/18 03:37 PM
^^^ good heads up info
Re: A Engine Offset Cam Keys? [Re: gtsdude] #2466269
03/14/18 10:59 AM
03/14/18 10:59 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have a belt drive now and don't have to deal with this but cam timing is based on 720 degrees. So a 4 degree key will affect the Intake Lobe Center 4 degrees. Correct?
