Page 1 of 2 1 2 >
#2463025 - 03/08/18 08:57 AM OEM Electrical connection and tools
fastmark Offline
Loc: Abilene, Texas
I need to repair some wiring harnesses and they have tools on eBay ranging from $4 to $400 to remove the terminals from the plastic connectors. The spades are easy but I need to remove some of the round ones in the ignition harness. I would also like to know where you can buy the factory style brass connectors. Anyone bought these that can give advice? Any thoughts on where you can buy the correct colored wires? Especially the ones with the tracer color. Thanks
Edited by fastmark (03/08/18 08:58 AM)
#2463053 - 03/08/18 10:02 AM Re: OEM Electrical connection and tools [Re: fastmark]
therocks Offline
Its Lost
Loc: Niles , Ohio
I have a set of tools from Packard that my brother had.He had like 20 sets at one time and sold a bunch on Ebay.They were toss outs as new stuff came out.They work great on almost all connectors.They do come up on Ebay at times from a few bucks to 40 or 50 depending on how many in a set.IIRC one company makes OE type connectors.I used to use some small scredrivers etc at work before i got my OE type tools.Rocky
Chrysler Firepower
#2463069 - 03/08/18 10:31 AM Re: OEM Electrical connection and tools [Re: fastmark]
Loc: Lincoln Nebraska
I would also like to know where you can buy the factory style brass connectors. Any thoughts on where you can buy the correct colored wires? Especially the ones with the tracer color. Thanks
NAPA has the common "packard 56" type male female terminals for the bulkhead 725145/725147 but they are pricey (99 cents ea). there are companies that sell em in bulk for way less (eBay likely). Yes you absolutely want to keep the same colors as OE including colors with tracers & there are companies out there who sell specific lengths of em & on some circuits you may want to go larger (as you know a smaller gauge). I dont have a specific company(s) but you might Google it.
#2463175 - 03/08/18 01:59 PM Re: OEM Electrical connection and tools [Re: therocks]
mikemee1331 Offline
Loc: bethlehem pa
i've always used jewelers screwdrivers to pop them apart. dollar stores usually has them or drug stores where they sell cheap reading glasses.
#2463268 - 03/08/18 04:14 PM Re: OEM Electrical connection and tools [Re: fastmark]
Evil Spirit Offline
Loc: Newport, Mi
Try Terminal Supply Co - they have several locations, plus I-net sales. Also Lectric Limited has a website. I've had good success with both.
Free advice and worth every penny... Factory trained Slinky rewinder.........
#2463301 - 03/08/18 05:16 PM Re: OEM Electrical connection and tools [Re: fastmark]
Mattax Offline
Loc: Phila. Pa.
Adding on to what others have said.
The Terminal styles are Packard 56. If you find some are larger, they are probably Packard 58 or 59.
Crib sheet to ID all sorts of automotive terminals & connectors:
http://www.rowand.net/shop/tech/automotiveelectricalconnectors.htm
Tools:
The crimpers needed are for "open barrel" terminals from 18 to at least 12, preferably 10 or 8 gage. The larger gages can come into use with smaller wires when joining two at a terminal. For example at the ballast resistor.
* American Autowire sells a set of proper crimpers, slightly less expensive than the real thing.
* Astro sells a nice compound action crimper but the jaws are too wide for the male terminals. The little wings at the bottom of the terminals (seen below) are in the way. frown
Terminal removal tool. Seems silly when a cotter pin or small screw driver will do, but they do save time and minimize damage. I think they are worth it. Best in use is the single prong version. Multi-prongs sometimes interfere with the adjacent terminal cavities.
Materials
Wire: My preference is from a marine supply center. Slightly more copper for any given gage size, tinned surface, and insulation suitable for engine compartments. They also have a ton of colors and can cut what you need. Second preference for engine compartment is wire with insulation for that environment (heat and oil) such as GXL or (IIRC) THWN rated insulation. Otherwise GPT (general purpose primary) is fine.
eg https://www.wirebarn.com/Wire-Selection-Guide-_ep_29.html
Another source for colored & trace marked wire: Rhode Island Wire http://www.riwire.com/
Terminals Sources:
Waytek Wire 56 series are catagorized under metripack here
Del City Del City
Terminal Supply Co.
Repair Connector store
Electrical Depot
I found with my jeep, which also used a lot Packard 56 type connectors, not all the terminals were like the original. Not just whether they had a tin plate, but the shoulder stops and lengths varied on some of the replacments. The one on the far left lacks the little wings at the bottom. How important is that? shruggy
#2463307 - 03/08/18 05:31 PM Re: OEM Electrical connection and tools [Re: Evil Spirit]
Michael Ecks Offline
Loc: Columbus, GA
iagree
Terminal Supply Co. was awesome to deal with. They don't mind working with hobbyists, so you can order just one or two terminals where everyone else wants to sell them 25count at a time. They'll have both the packard 56 tools and the round ones.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
#2463424 - 03/08/18 08:24 PM Re: OEM Electrical connection and tools [Re: fastmark]
1971 Gran Coupe Offline
Loc: Washington/Las Vegas
When I ordered some of the Packard connectors they included a catalog with what they have. It is amazing how many different wire terminals they carry.
#2463428 - 03/08/18 08:32 PM Re: OEM Electrical connection and tools [Re: fastmark]
frank Offline
Loc: tucson az
I use GXL or TXL wire from The Wirebarn. They have many colors but I don't know if they have the "correct" color or wire with the tracer.
#2463608 - 03/09/18 07:47 AM Re: OEM Electrical connection and tools [Re: 1971 Gran Coupe]
fastmark Offline
Loc: Abilene, Texas
What company did you get you catalog from?
I found the American wire website and found out the one mostly used appears to be the Packard 56. I still have not found the round ones like go in the ignition and turn signal switch. I have not searched for wire yet. Thanks guys. This will help. I’ll get digging on the net. 👍👍
#2463636 - 03/09/18 08:48 AM Re: OEM Electrical connection and tools [Re: fastmark]
If you order anything however small (but Mopar specific) from www.classicindustries.com online then in several weeks their comprehensive $12.95 Mopar catalogue will arrive unexpectedly in your mailbox for free & it is a treasure trove of pics of many varieties of items including electrical. it is a must have reference manual.
#2463667 - 03/09/18 09:33 AM Re: OEM Electrical connection and tools [Re: fastmark]
68Cbarge Offline
Loc: Canuckville
This thread is very informative,thank you!
Handy since I do a lot of mopar rewiring!
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
#2463673 - 03/09/18 09:44 AM Re: OEM Electrical connection and tools [Re: 68Cbarge]
moparx Online   content
Dreaming of implants
Loc: north of coder
i use "molex" terminals [i think that's the name. there is nothing on the box i have.] for the ignition/turn signal connection. there are two sizes. .093 for the turn signal wires, and .125 for the ignition/accessory wires. these sure look like the OEM terminals.
beer
#2463681 - 03/09/18 10:05 AM Re: OEM Electrical connection and tools [Re: fastmark]
bboogieart Offline
Loc: Lost and Spaced
You actually erased it from the post you quoted.
I have mechanical Aptitude.
I can screw up anything.
#2463699 - 03/09/18 10:28 AM Re: OEM Electrical connection and tools [Re: fastmark]
Stanton Offline
Loc: Ontario, Canada
I ordered one of these (yes, its made and comes from China). Its very well made BUT the actual crimp heads are made from die cast and I broke one doing one of the male connectors (those suckers are pretty thick brass). I was probably a little over zealous too. Anyhow, I just ordered 6 more of the crimp heads (they're dirt cheap). I'd suggest if you order the tool, order extra crimp heads at the same time "just in case". And make sure you order the correct head(s)
https://www.ebay.com/itm/Wire-Ratchet-Crimping-Pliers-Terminal-Crimper-Clamp-Tool-0-14-1-5mm-JX-1601-08/322591910229?hash=item4b1bf9e955:g:whYAAOSwRvdZaIJe
#2463701 - 03/09/18 10:29 AM Re: OEM Electrical connection and tools [Re: fastmark]
a12rag Offline
Loc: Calgary, Alberta Canada
Need to find a store (Harbour Freight maybe ??) . . that has these :
#2463745 - 03/09/18 11:34 AM Re: OEM Electrical connection and tools [Re: fastmark]
Mattax Offline
Loc: Phila. Pa.
As I posted above, the double prongs can get in the way when working on a multi-cavity connectors. Go for a single prong version.
This photo from the Civilian Jeep forum shows the retaining tab the tool is used to release.
#2463910 - 03/09/18 04:16 PM Re: OEM Electrical connection and tools [Re: fastmark]
The company is Terminal supply. http://terminalsupplyco.com
The email here is from the person I was working with, very knowledgeable and knows what the products are----
Julie.Szefler@terminalsupplyco.com
#2463992 - 03/09/18 05:59 PM Re: OEM Electrical connection and tools [Re: 1971 Gran Coupe]
convertcuda Offline
Loc: Wausau Wi
Is there a special crim tool thats used for these terminals?
#2464045 - 03/09/18 06:48 PM Re: OEM Electrical connection and tools [Re: convertcuda]
I picked one similar to the one on ebay.
https://www.ebay.com/itm/New-Made-Open-S...er/182588509911
Page 1 of 2 1 2 >
25,341 Registered Members
190,140 Topics
Most users ever online: 1,417 @ 06/18/18 08:39 PM
Mopars at the Patch 2018
by 11secdart
06/18/18 09:30 PM
Mopars at the Patch
by 11secdart
06/18/18 09:28 PM
My Thumper inspired dominator....
by dartman366
06/18/18 09:03 PM
Recommend a resto shop for my wife's 64?
by not_a_charger
06/18/18 08:50 PM
