Re: A Engine Offset Cam Keys?
[Re: rarefish]
#2463425
03/08/18 11:26 PM
03/08/18 11:26 PM
RapidRobert
I want another set & could not find em. I would suggest a 3 keyway timing chain set of the quality level that you want. Other than that: ebay or CL or maybe another mopar site (FABO wanted might be good).
[Re: rarefish]
#2463443
03/08/18 11:53 PM
03/08/18 11:53 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I have a few of them right now, but a friend called me tonight looking for a 4 deg key. Does anyone know what color that key is? I have the info in the shop. but it'll be tomorrow before I'll be back out there. When I built my 408 I needed one that I didn't have and a member sent me one at no charge. A few months later someone here needed one that I did have so I returned the favor that was given to me. I did later buy a set off the bag.
[Re: forphorty]
#2463477
03/09/18 12:40 AM
03/09/18 12:40 AM
Posts: 20,144 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Summit stocks any key you should need. I buy all of mine there.
[Re: pittsburghracer]
#2463518
03/09/18 01:40 AM
03/09/18 01:40 AM
RapidRobert
I only see the "round" BB ones at Summit. the SB ones sorta look like a cam key with the top half of it "shifted/offset" over which shifts the cam gear.
#2463519
03/09/18 01:42 AM
03/09/18 01:42 AM
Posts: 10,694 North Dakota
6PakBee
North Dakota
Summit stocks any key you should need. I buy all of mine there. I couldn't find any key for a B/RB other than the 0 degree.
[Re: Porter67]
#2463848
03/09/18 05:00 PM
03/09/18 05:00 PM
justinp61
W. Kentucky
Looks like so far ive got a yellow and a blue, I dont recall doing it but I must of as the blue is marked 3 and the yellow 4.
If you can use them pm me your addy and I will toss them in a envelope.
I still think ive one more, like a brown one. My noted indicate the same, yellow is 4°.
[Re: justinp61]
#2464031
03/09/18 09:36 PM
03/09/18 09:36 PM
Posts: 20,144 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks a lot guys you jinxed me. I'm putting my 572 together today and throw the timing cover on and want to install my ATI damper on to check my timing marks before I install the heads this weekend. Well my machinist must have removed my key to do his work and it didn't get reinstalled. Usually not an issue but this is a Calias crank with a 1/4 inch keyway instead of a 3/16 so it uses a 1/4-3/16 stepped key. I have over 20 keys here but of coarse no stepped keys so I found one on Summits site for 18.00 and it should be here Monday or Tuesday. Oh well I guess I will be building the transmission for it instead. LOL
[Re: Mopar Sam]
#2465721
03/13/18 12:47 PM
03/13/18 12:47 PM
Posts: 902 S.E. Minnesota
gtsdude
S.E. Minnesota
The Mr. Gasket ones are sometimes listed as small block chevy crankshaft keys. I used this one, just remember its the camshaft you are moving, not the crank like this one is made for. If you want 4 degrees advance, get a 2 degree key.
[Re: gtsdude]
#2466269
03/14/18 10:59 AM
03/14/18 10:59 AM
Posts: 3,507 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I used this one, just remember its the camshaft you are moving, not the crank like this one is made for. If you want 4 degrees advance, get a 2 degree key. I have a belt drive now and don't have to deal with this but cam timing is based on 720 degrees. So a 4 degree key will affect the Intake Lobe Center 4 degrees. Correct?
[Re: 340Cuda]
#2466443
03/14/18 04:03 PM
03/14/18 04:03 PM
gtsdude
S.E. Minnesota
I used this one, just remember its the camshaft you are moving, not the crank like this one is made for. If you want 4 degrees advance, get a 2 degree key. I have a belt drive now and don't have to deal with this but cam timing is based on 720 degrees. So a 4 degree key will affect the Intake Lobe Center 4 degrees. Correct? That is correct as long as it is a 4 degree cam key not a a 4 degree crank key you are using as a cam key.
[Re: gtsdude]
#2466477
03/14/18 05:05 PM
03/14/18 05:05 PM
Posts: 20,144 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I hope you degree this cam in because who knows where it’s installed at. I’ve found them up to 22 degrees off
