#2462943 - 03/07/18 10:49 PM Removing center link?
500ciBee Offline
Loc: Ontario, Canada
I need to remove the center link to swap out the headers on my Bee. The center link passes between the tubes of the headers. I'm not sure what is the best method to getting the center link off. I've tried hitting it about as hard as I think is safe. What do you guys suggest?
Edited by 500ciBee (03/07/18 10:51 PM)
1970 Super Bee prostreet. 383, SMR 727, Dana 60 4:88. Building a 512 low deck.
#2462951 - 03/07/18 11:16 PM Re: Removing center link? [Re: 500ciBee]
GoodysGotaCuda Offline
5.7L Hemi, 6spd
Loc: Texas
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
1976 Dodge Warlock - "Her Truck" - 360/727 2wd
1969 Dodge Dart Custom Sedan - Grandma Edition - 318/904
2016 Subaru WRX - E30 Tune ~320whp
#2463236 - 03/08/18 03:37 PM Re: Removing center link? [Re: 500ciBee]
500ciBee Offline
Thanks! I'll pickup one those.
#2464185 - 03/10/18 05:36 AM Re: Removing center link? [Re: 500ciBee]
BigBlockMopar Offline
Loc: The Netherlands
You can usually pop ball joints with use of two large (±5 lbs) hammers.
Put one (the largest) hammer behind and hit the metal from the front.
Of course you don't whack the balljoint itself, but the part that it's protruding.
Leave the nut loose on the threads in case you hit it wrong.
BigBlockMopar.com
#2468170 - 03/18/18 03:10 PM Re: Removing center link? [Re: 500ciBee]
500ciBee Offline
I bought a ball joint separator but there is no way the tool will fit between the idler arm and center link. I've hit it enough that I think it should have come apart. Should I remove the idler from the frame?
#2468198 - 03/18/18 04:15 PM Re: Removing center link? [Re: 500ciBee]
5.7L Hemi, 6spd
Loc: Texas
May need to tap it in a little. Mine worked perfectly..
25,630 Registered Members
195,574 Topics
Original Mr. Norm’s T-Shirt
by floyd
12/13/18 09:58 AM
AAA roadside replacement battery?
by magnum440d100
12/13/18 09:27 AM
Save Money & Get Free Swag With SST’s Santa’s Swag Sale
by Rustymuscle
12/13/18 09:06 AM
My favorite Christmas song
by bigdad
12/13/18 09:02 AM
