#2462766 - 03/07/18 05:25 PM Phenolic or Metal caliper piston?
BDW Offline
Loc: Florida
I see rebuilt brake calipers listed with Phenolic or metal pistons.
No real difference in price, so which is better?
Phenolic Is ceramic/plastic based, so no rust issues.
Metal might be stronger with less deflection?
Which would you choose?
Thx
#2462768 - 03/07/18 05:29 PM Re: Phenolic or Metal caliper piston? [Re: BDW]
jcastle1 Offline
Loc: Cincinnati,Ohio
it does not matter, just make sure the pair are the same
#2462803 - 03/07/18 06:37 PM Re: Phenolic or Metal caliper piston? [Re: BDW]
Andrewh Offline
there was an issue at one point for the phenolic ones so I always go metal.
they recalled them because it would cause the caliper to lock up and keep the brakes on till they cooled.
had it happen with an 84 new yorker. mbody car.
#2462863 - 03/07/18 08:05 PM Re: Phenolic or Metal caliper piston? [Re: BDW]
therocks Offline
Its Lost
Loc: Niles , Ohio
I agree had problems with Phonelics sometimes.I use metal.Rocky
Chrysler Firepower
#2463141 - 03/08/18 12:58 PM Re: Phenolic or Metal caliper piston? [Re: BDW]
jcc Offline
No politics
Loc: Trumussia
"Phenolic Is ceramic/plastic based, so no rust issues."
Are we talking 70's stuff, never heard the ceramic description before.
Not sure rust is that much of a problem anyway if using a CI caliper.
I suspect phenolic was a cheaper solution, I would chose alum between the two. twocents
Seeking more civil pastures
#2463163 - 03/08/18 01:46 PM Re: Phenolic or Metal caliper piston? [Re: jcc]
dogdays Offline
Phenolic....."a usually thermosetting resin or plastic made by condensation of a phenol with an aldehyde and used especially for molding and insulating and in coatings and adhesives — called also phenolic resin."
There are no ceramics in phenolic.
On the first Ford Tauruses, the standard cars got phenolic caliper pistons, the cop and taxi and SHO models got metal pistons. So in that case metal pistons were more high performance.
Regarding thermal linear expansion, phenolic is 6 times the expansion of steel, 4 times the expansion of stainless steel, and 3 times the expansion of aluminum. Numbers were rounded.
So phenolic expands more per degree increase than three common metals.
Go with the metal pistons.
R.
#2463238 - 03/08/18 03:41 PM Re: Phenolic or Metal caliper piston? [Re: dogdays]
horsepower.2007 Offline
Loc: western new york
I had phenolic calipers on my lil red, They stuck all the time.
25,631 Registered Members
195,640 Topics
How I keep track of my "Barn Finds"
by Devil
12/14/18 11:43 PM
361 bb stroker
by orange elephants
12/14/18 10:57 PM
charger Rallye dash cluster bulb locations
by lockjaw-express
12/14/18 10:42 PM
boarding my garage
by Superfreak
12/14/18 09:47 PM
