OEM Electrical connection and tools #2463025
03/08/18 11:57 AM
03/08/18 11:57 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I need to repair some wiring harnesses and they have tools on eBay ranging from $4 to $400 to remove the terminals from the plastic connectors. The spades are easy but I need to remove some of the round ones in the ignition harness. I would also like to know where you can buy the factory style brass connectors. Anyone bought these that can give advice? Any thoughts on where you can buy the correct colored wires? Especially the ones with the tracer color. Thanks
Re: OEM Electrical connection and tools [Re: fastmark] #2463053
03/08/18 01:02 PM
03/08/18 01:02 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have a set of tools from Packard that my brother had.He had like 20 sets at one time and sold a bunch on Ebay.They were toss outs as new stuff came out.They work great on almost all connectors.They do come up on Ebay at times from a few bucks to 40 or 50 depending on how many in a set.IIRC one company makes OE type connectors.I used to use some small scredrivers etc at work before i got my OE type tools.Rocky
Chrysler Firepower
Re: OEM Electrical connection and tools [Re: fastmark] #2463069
03/08/18 01:31 PM
03/08/18 01:31 PM
I would also like to know where you can buy the factory style brass connectors. Any thoughts on where you can buy the correct colored wires? Especially the ones with the tracer color. Thanks
NAPA has the common "packard 56" type male female terminals for the bulkhead 725145/725147 but they are pricey (99 cents ea). there are companies that sell em in bulk for way less (eBay likely). Yes you absolutely want to keep the same colors as OE including colors with tracers & there are companies out there who sell specific lengths of em & on some circuits you may want to go larger (as you know a smaller gauge). I dont have a specific company(s) but you might Google it.
Re: OEM Electrical connection and tools [Re: therocks] #2463175
03/08/18 04:59 PM
03/08/18 04:59 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i've always used jewelers screwdrivers to pop them apart. dollar stores usually has them or drug stores where they sell cheap reading glasses.
Re: OEM Electrical connection and tools [Re: fastmark] #2463268
03/08/18 07:14 PM
03/08/18 07:14 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Try Terminal Supply Co - they have several locations, plus I-net sales. Also Lectric Limited has a website. I've had good success with both.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: OEM Electrical connection and tools [Re: fastmark] #2463301
03/08/18 08:16 PM
03/08/18 08:16 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Adding on to what others have said.
The Terminal styles are Packard 56. If you find some are larger, they are probably Packard 58 or 59.
Crib sheet to ID all sorts of automotive terminals & connectors:
http://www.rowand.net/shop/tech/automotiveelectricalconnectors.htm
Tools:
The crimpers needed are for "open barrel" terminals from 18 to at least 12, preferably 10 or 8 gage. The larger gages can come into use with smaller wires when joining two at a terminal. For example at the ballast resistor.
* American Autowire sells a set of proper crimpers, slightly less expensive than the real thing.
* Astro sells a nice compound action crimper but the jaws are too wide for the male terminals. The little wings at the bottom of the terminals (seen below) are in the way. frown
Terminal removal tool. Seems silly when a cotter pin or small screw driver will do, but they do save time and minimize damage. I think they are worth it. Best in use is the single prong version. Multi-prongs sometimes interfere with the adjacent terminal cavities.
Materials
Wire: My preference is from a marine supply center. Slightly more copper for any given gage size, tinned surface, and insulation suitable for engine compartments. They also have a ton of colors and can cut what you need. Second preference for engine compartment is wire with insulation for that environment (heat and oil) such as GXL or (IIRC) THWN rated insulation. Otherwise GPT (general purpose primary) is fine.
eg https://www.wirebarn.com/Wire-Selection-Guide-_ep_29.html
Another source for colored & trace marked wire: Rhode Island Wire http://www.riwire.com/
Terminals Sources:
Waytek Wire 56 series are catagorized under metripack here
Del City Del City
Terminal Supply Co.
Repair Connector store
Electrical Depot
I found with my jeep, which also used a lot Packard 56 type connectors, not all the terminals were like the original. Not just whether they had a tin plate, but the shoulder stops and lengths varied on some of the replacments. The one on the far left lacks the little wings at the bottom. How important is that? shruggy
Re: OEM Electrical connection and tools [Re: Evil Spirit] #2463307
03/08/18 08:31 PM
03/08/18 08:31 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
iagree
Terminal Supply Co. was awesome to deal with. They don't mind working with hobbyists, so you can order just one or two terminals where everyone else wants to sell them 25count at a time. They'll have both the packard 56 tools and the round ones.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: OEM Electrical connection and tools [Re: fastmark] #2463424
03/08/18 11:24 PM
03/08/18 11:24 PM
Washington/Las Vegas
1971 Gran Coupe Offline
When I ordered some of the Packard connectors they included a catalog with what they have. It is amazing how many different wire terminals they carry.
Re: OEM Electrical connection and tools [Re: fastmark] #2463428
03/08/18 11:32 PM
03/08/18 11:32 PM
tucson az
frank Offline
frank  Offline
tucson az
I use GXL or TXL wire from The Wirebarn. They have many colors but I don't know if they have the "correct" color or wire with the tracer.
Re: OEM Electrical connection and tools [Re: 1971 Gran Coupe] #2463608
03/09/18 10:47 AM
03/09/18 10:47 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
What company did you get you catalog from?
I found the American wire website and found out the one mostly used appears to be the Packard 56. I still have not found the round ones like go in the ignition and turn signal switch. I have not searched for wire yet. Thanks guys. This will help. I’ll get digging on the net. 👍👍
Re: OEM Electrical connection and tools [Re: fastmark] #2463636
03/09/18 11:48 AM
03/09/18 11:48 AM
If you order anything however small (but Mopar specific) from www.classicindustries.com online then in several weeks their comprehensive $12.95 Mopar catalogue will arrive unexpectedly in your mailbox for free & it is a treasure trove of pics of many varieties of items including electrical. it is a must have reference manual.
Re: OEM Electrical connection and tools [Re: fastmark] #2463667
03/09/18 12:33 PM
03/09/18 12:33 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
This thread is very informative,thank you!
Handy since I do a lot of mopar rewiring!
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: OEM Electrical connection and tools [Re: 68Cbarge] #2463673
03/09/18 12:44 PM
03/09/18 12:44 PM
moparx Offline
moparx  Offline
i use "molex" terminals [i think that's the name. there is nothing on the box i have.] for the ignition/turn signal connection. there are two sizes. .093 for the turn signal wires, and .125 for the ignition/accessory wires. these sure look like the OEM terminals.
beer
Re: OEM Electrical connection and tools [Re: fastmark] #2463681
03/09/18 01:05 PM
03/09/18 01:05 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
You actually erased it from the post you quoted.
I have mechanical Aptitude.
I can screw up anything.
Re: OEM Electrical connection and tools [Re: fastmark] #2463699
03/09/18 01:28 PM
03/09/18 01:28 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I ordered one of these (yes, its made and comes from China). Its very well made BUT the actual crimp heads are made from die cast and I broke one doing one of the male connectors (those suckers are pretty thick brass). I was probably a little over zealous too. Anyhow, I just ordered 6 more of the crimp heads (they're dirt cheap). I'd suggest if you order the tool, order extra crimp heads at the same time "just in case". And make sure you order the correct head(s)
https://www.ebay.com/itm/Wire-Ratchet-Crimping-Pliers-Terminal-Crimper-Clamp-Tool-0-14-1-5mm-JX-1601-08/322591910229?hash=item4b1bf9e955:g:whYAAOSwRvdZaIJe
Re: OEM Electrical connection and tools [Re: fastmark] #2463701
03/09/18 01:29 PM
03/09/18 01:29 PM
Calgary, Alberta Canada
a12rag Online content
a12rag  Online Content
Need to find a store (Harbour Freight maybe ??) . . that has these :
Re: OEM Electrical connection and tools [Re: fastmark] #2463745
03/09/18 02:34 PM
03/09/18 02:34 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
As I posted above, the double prongs can get in the way when working on a multi-cavity connectors. Go for a single prong version.
This photo from the Civilian Jeep forum shows the retaining tab the tool is used to release.
Re: OEM Electrical connection and tools [Re: fastmark] #2463910
03/09/18 07:16 PM
03/09/18 07:16 PM
The company is Terminal supply. http://terminalsupplyco.com
The email here is from the person I was working with, very knowledgeable and knows what the products are----
Julie.Szefler@terminalsupplyco.com
Re: OEM Electrical connection and tools [Re: 1971 Gran Coupe] #2463992
03/09/18 08:59 PM
03/09/18 08:59 PM
Wausau Wi
Convertcuda Offline
Convertcuda  Offline
Wausau Wi
Is there a special crim tool thats used for these terminals?
Re: OEM Electrical connection and tools [Re: Convertcuda] #2464045
03/09/18 09:48 PM
03/09/18 09:48 PM
I picked one similar to the one on ebay.
https://www.ebay.com/itm/New-Made-Open-S...er/182588509911
