Computech data logger #2462804
03/07/18 09:38 PM
03/07/18 09:38 PM
nc
E
earthmover Offline OP
E
nc
Any of you guys have experience with them ..i see they start around 1800 .thanks
Re: Computech data logger [Re: earthmover] #2462841
03/07/18 10:45 PM
03/07/18 10:45 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I would not spend that kind of money on a logger when you can buy an efi system with logging, fuel and ignition control all in one package. You could use the efi box as a logger only if you wanted to.
The only reason that I would possibly go with an external logger would be if I was long duration road racing and needed track telemetry or some such thing.
Always do your homework for total needs/ compatibility.
Re: Computech data logger [Re: TRENDZ] #2462862
03/07/18 11:05 PM
03/07/18 11:05 PM
nc
E
E
nc
Which system trendz..that sounds pretty good
Re: Computech data logger [Re: earthmover] #2462870
03/07/18 11:13 PM
03/07/18 11:13 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
That would be an easier question to answer if you had a comlpete list of the things you would like to log.
I would bet most of the votes from others would be the Holley Dominator EFI, or Megasquirt MS3 pro, but there are many others to choose from.
Re: Computech data logger [Re: TRENDZ] #2462960
03/08/18 02:49 AM
03/08/18 02:49 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I agree, I was going to say the same thing. Don't skimp and you will be happy
Re: Computech data logger [Re: FastmOp] #2463044
03/08/18 12:41 PM
03/08/18 12:41 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
X2...
Even though the class I will be running does not allow fuel injection I hope to get a Megasquirt for data logging and to run Coil Near Plug ignition.
