Computech data logger
#2462804
03/07/18 09:38 PM
03/07/18 09:38 PM
Posts: 2,449 nc
earthmover
nc
Any of you guys have experience with them ..i see they start around 1800 .thanks
Re: Computech data logger
[Re: earthmover]
#2462841
03/07/18 10:45 PM
03/07/18 10:45 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I would not spend that kind of money on a logger when you can buy an efi system with logging, fuel and ignition control all in one package. You could use the efi box as a logger only if you wanted to. The only reason that I would possibly go with an external logger would be if I was long duration road racing and needed track telemetry or some such thing. Always do your homework for total needs/ compatibility.
[Re: earthmover]
#2462870
03/07/18 11:13 PM
03/07/18 11:13 PM
TRENDZ
Milwaukee WI
That would be an easier question to answer if you had a comlpete list of the things you would like to log. I would bet most of the votes from others would be the Holley Dominator EFI, or Megasquirt MS3 pro, but there are many others to choose from.
[Re: TRENDZ]
#2462960
03/08/18 02:49 AM
03/08/18 02:49 AM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
I would not spend that kind of money on a logger when you can buy an efi system with logging, fuel and ignition control all in one package. You could use the efi box as a logger only if you wanted to. The only reason that I would possibly go with an external logger would be if I was long duration road racing and needed track telemetry or some such thing. Always do your homework for total needs/ compatibility. I agree, I was going to say the same thing. Don't skimp and you will be happy
[Re: FastmOp]
#2463044
03/08/18 12:41 PM
03/08/18 12:41 PM
Posts: 3,496 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
X2... Even though the class I will be running does not allow fuel injection I hope to get a Megasquirt for data logging and to run Coil Near Plug ignition.
