#2462804 - 03/07/18 06:38 PM Computech data logger
earthmover Offline
Loc: nc
Any of you guys have experience with them ..i see they start around 1800 .thanks
Edited by earthmover (03/07/18 07:02 PM)
#2462841 - 03/07/18 07:45 PM Re: Computech data logger [Re: earthmover]
TRENDZ Offline
Loc: Milwaukee WI
I would not spend that kind of money on a logger when you can buy an efi system with logging, fuel and ignition control all in one package. You could use the efi box as a logger only if you wanted to.
The only reason that I would possibly go with an external logger would be if I was long duration road racing and needed track telemetry or some such thing.
Always do your homework for total needs/ compatibility.
#2462862 - 03/07/18 08:05 PM Re: Computech data logger [Re: TRENDZ]
earthmover Offline
Loc: nc
Which system trendz..that sounds pretty good
#2462870 - 03/07/18 08:13 PM Re: Computech data logger [Re: earthmover]
TRENDZ Offline
Loc: Milwaukee WI
That would be an easier question to answer if you had a comlpete list of the things you would like to log.
I would bet most of the votes from others would be the Holley Dominator EFI, or Megasquirt MS3 pro, but there are many others to choose from.
#2462960 - 03/07/18 11:49 PM Re: Computech data logger [Re: TRENDZ]
FastmOp Offline
Loc: Hot Rod Ridge
I agree, I was going to say the same thing. Don't skimp and you will be happy
#2463044 - 03/08/18 09:41 AM Re: Computech data logger [Re: FastmOp]
340Cuda Offline
Loc: Tulsa, Oklahoma
X2...
Even though the class I will be running does not allow fuel injection I hope to get a Megasquirt for data logging and to run Coil Near Plug ignition.
25,486 Registered Members
193,008 Topics
When you and your friend have a lot of extra fiberglass
by bigdad
09/21/18 12:09 PM
Ignorant question about LBA valve body
by BradH
09/21/18 12:05 PM
Fuel Pump Pressure Variation
by gzig5
09/21/18 11:10 AM
1957 Dodge fire truck , Sioux Falls ,SD area $3000
by bigdad
09/21/18 10:57 AM
