#2461951 - 03/06/18 09:16 AM 71 Cuda Rocker Mouldings- Yes or NO
440PURSUIT Offline
Loc: DC, MD Suburbs
When did cars come with this trim?
I plan on doing a 71 Cuda Convertible clone and wonder if this mouldings is
A necessary addition or preference.
They seem to be for 71-2 and are rather pricey NOS
1969 Hemi Charger R/T,
1969 Charger RT Clone
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1969 Dart GTS 340 Convert
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Road Runner 340-4
1972 Charger Rallye 400-4
1972 Charger w 383
1972 Sebring Plus 440-6 Clone
1967 A100
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
2006 Dodge Magnum 5.7
2017 3500 Dually
#2461973 - 03/06/18 10:12 AM Re: 71 Cuda Rocker Mouldings- Yes or NO [Re: 440PURSUIT]
biggE Offline
Loc: California
The rocker trim was standard on all 71 cuda's
#2462780 - 03/07/18 05:53 PM Re: 71 Cuda Rocker Mouldings- Yes or NO [Re: biggE]
Little Detroit Offline
Loc: WV
if you want to get that rocker molding cheap go to your local chevy dealer and order a pair for a 69 Camaro. same exact molding was used on 69 dart , 69 Camaro and 71 cuda .
#2462789 - 03/07/18 06:03 PM Re: 71 Cuda Rocker Mouldings- Yes or NO [Re: 440PURSUIT]
hemicar1971 Offline
Loc: Chicago Blackhawks
Cloning a 1971 Cuda Convertible you will need the rocker trim, door and quarter window trim on top of the door and quarter, rear panel trim four pieces and all is coded on a CUDAs fender tag and broadcast sheet. Also the louvers for the fenders. You will have to weld in the proper studs or use the body repair studs for all trim.
1971 HEMI E BODY REGISTRY
#2463834 - 03/09/18 01:30 PM Re: 71 Cuda Rocker Mouldings- Yes or NO [Re: Little Detroit]
440PURSUIT Offline
Loc: DC, MD Suburbs
On the Camaro mouldings...
Wow, that’s good to know. A friend has NOS mopar and wants a lot for them
1972 Charger w 383
1967 A100
2017 3500 Dually
25,622 Registered Members
195,479 Topics
ROLLER CAM LOW LIFT FLOW HEADS
by A/MP
12/09/18 09:42 PM
76 d100 gas tank filler neck replacement
by 76_d100
12/09/18 09:22 PM
Trick Flow 240 Heads
by RROD
12/09/18 09:12 PM
Looking for In order of preference ignition system
by modelmakerinc
12/09/18 08:25 PM
