71 Cuda Rocker Mouldings- Yes or NO #2461951
03/06/18 12:16 PM
03/06/18 12:16 PM
DC, MD Suburbs
440PURSUIT Offline OP
DC, MD Suburbs
When did cars come with this trim?
I plan on doing a 71 Cuda Convertible clone and wonder if this mouldings is
A necessary addition or preference.
They seem to be for 71-2 and are rather pricey NOS
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger w 383
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1997 Ram B3500 Van 5.9
1991.5 W250 Cummins- Big Chief
Re: 71 Cuda Rocker Mouldings- Yes or NO [Re: 440PURSUIT] #2461973
03/06/18 01:12 PM
03/06/18 01:12 PM
California
biggE Offline
biggE  Offline
California
The rocker trim was standard on all 71 cuda's
Re: 71 Cuda Rocker Mouldings- Yes or NO [Re: biggE] #2462780
03/07/18 08:53 PM
03/07/18 08:53 PM
WV
Little Detroit Offline
WV
if you want to get that rocker molding cheap go to your local chevy dealer and order a pair for a 69 Camaro. same exact molding was used on 69 dart , 69 Camaro and 71 cuda .
Re: 71 Cuda Rocker Mouldings- Yes or NO [Re: 440PURSUIT] #2462789
03/07/18 09:03 PM
03/07/18 09:03 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Cloning a 1971 Cuda Convertible you will need the rocker trim, door and quarter window trim on top of the door and quarter, rear panel trim four pieces and all is coded on a CUDAs fender tag and broadcast sheet. Also the louvers for the fenders. You will have to weld in the proper studs or use the body repair studs for all trim.
1971 HEMI E BODY REGISTRY
Re: 71 Cuda Rocker Mouldings- Yes or NO [Re: Little Detroit] #2463834
03/09/18 04:30 PM
03/09/18 04:30 PM
DC, MD Suburbs
DC, MD Suburbs
On the Camaro mouldings...
Wow, that’s good to know. A friend has NOS mopar and wants a lot for them
1972 Charger w 383
