Phenolic or Metal caliper piston? #2462766
03/07/18 08:25 PM
03/07/18 08:25 PM
BDW Offline OP
BDW  Offline OP
I see rebuilt brake calipers listed with Phenolic or metal pistons.
No real difference in price, so which is better?
Phenolic Is ceramic/plastic based, so no rust issues.
Metal might be stronger with less deflection?
Which would you choose?
Thx
Re: Phenolic or Metal caliper piston? [Re: BDW] #2462768
03/07/18 08:29 PM
03/07/18 08:29 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
it does not matter, just make sure the pair are the same
Re: Phenolic or Metal caliper piston? [Re: BDW] #2462803
03/07/18 09:37 PM
03/07/18 09:37 PM
Andrewh Offline
Andrewh  Offline
there was an issue at one point for the phenolic ones so I always go metal.
they recalled them because it would cause the caliper to lock up and keep the brakes on till they cooled.
had it happen with an 84 new yorker. mbody car.
Re: Phenolic or Metal caliper piston? [Re: BDW] #2462863
03/07/18 11:05 PM
03/07/18 11:05 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree had problems with Phonelics sometimes.I use metal.Rocky
Chrysler Firepower
Re: Phenolic or Metal caliper piston? [Re: BDW] #2463141
03/08/18 03:58 PM
03/08/18 03:58 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
"Phenolic Is ceramic/plastic based, so no rust issues."
Are we talking 70's stuff, never heard the ceramic description before.
Not sure rust is that much of a problem anyway if using a CI caliper.
I suspect phenolic was a cheaper solution, I would chose alum between the two. twocents
Re: Phenolic or Metal caliper piston? [Re: jcc] #2463163
03/08/18 04:46 PM
03/08/18 04:46 PM
dogdays Offline
dogdays  Offline
Phenolic....."a usually thermosetting resin or plastic made by condensation of a phenol with an aldehyde and used especially for molding and insulating and in coatings and adhesives — called also phenolic resin."
There are no ceramics in phenolic.
On the first Ford Tauruses, the standard cars got phenolic caliper pistons, the cop and taxi and SHO models got metal pistons. So in that case metal pistons were more high performance.
Regarding thermal linear expansion, phenolic is 6 times the expansion of steel, 4 times the expansion of stainless steel, and 3 times the expansion of aluminum. Numbers were rounded.
So phenolic expands more per degree increase than three common metals.
Go with the metal pistons.
R.
Re: Phenolic or Metal caliper piston? [Re: dogdays] #2463238
03/08/18 06:41 PM
03/08/18 06:41 PM
western new york
horsepower.2007 Offline
western new york
I had phenolic calipers on my lil red, They stuck all the time.
