Re: pics of electruc fuel set up underneath by the gas tank
[Re: mopar muscle7271]
#2471588
03/24/18 11:14 PM
03/24/18 11:14 PM
Posts: 22,695 Bitopia
jcc
Bitopia
What a dumb reply,keep that bs to yourself. Noted.
[Re: jcc]
#2471598
03/24/18 11:32 PM
03/24/18 11:32 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
It will take only one muscle car with a rear mounted exposed electric fuel pump to be involved in a fender bender with a loaded school bus for all this electric fuel DIYI upgrades to go legally bye bye. Taking that into account, installing one of these might save you and your car also. https://www.summitracing.com/parts/rfw-cr92/overview/ How about putting late model airbags in it and an aftermarket ABS kit too Do you actually have an old car and if you do does it have all these politically correct additions? Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
#2471783
03/25/18 01:44 PM
03/25/18 01:44 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Are you retarded and cant read what my post says. He wasn’t replying to you, or are you too retarded to read?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: fourgearsavoy]
#2471788
03/25/18 01:54 PM
03/25/18 01:54 PM
jcc
Bitopia
It will take only one muscle car with a rear mounted exposed electric fuel pump to be involved in a fender bender with a loaded school bus for all this electric fuel DIYI upgrades to go legally bye bye. Taking that into account, installing one of these might save you and your car also. https://www.summitracing.com/parts/rfw-cr92/overview/ How about putting late model airbags in it and an aftermarket ABS kit too Do you actually have an old car and if you do does it have all these politically correct additions? Gus 1. I don't see an applicable ABS listed on Summits website 2. If I did, I would not categorically dismiss the upgrade 3. I don't see an airbag upgrade on the Summit website 4. Me not having an airbag in my old muscle car will not cause a number of school kids to be burnt while a poorly installed aftermarket fuel pump gushes fuel in a fender bender with a school bus, disregarding what danger me or my car my suffer 5. Yes I have an old cars, and they are younger then me 6. I have installed the suggested linked fuel cut-off when using an electric fuel pump 7. I also installed seat/shoulder belts in my cars that came originally with none 8. Mentioning PC is just a low hanging fruit argument
#2471808
03/25/18 02:33 PM
03/25/18 02:33 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Mines in the tank
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: BDW]
#2472031
03/25/18 10:49 PM
03/25/18 10:49 PM
jcc
Bitopia
What exactly triggers that crash relay? I believe the summit device is basically a Ford crash inertial relay (an enclosed suspended steel ball on a magnetic contact?). On my son's 5.0 Mustang hatch back, slamming the rear hatch hard would activate it, it was OEM mounted inches from the latch. On my cars its mounted on the firewall, an intended kick will activate it while I am exiting, and if that kick is during So Fla carjacking, the car will go maybe a block and tun out of gas in the middle of the next intersection, at least that is the plan. I have never been in a wreck in my cars with it.
[Re: BDW]
#2472104
03/26/18 01:38 AM
03/26/18 01:38 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Ok, so how do you reset it? It looks like something that might be worthwhile if it's not more pain than it's worth? Push the big red button. If you have to reset it, that's probably the least of your worries, it's pretty hard to trip unless it's mounted to something floppy.
[Re: jcc]
#2488790
04/27/18 07:40 PM
04/27/18 07:40 PM
Porter67
Thats the first thing ya want to bypass if you street race hard or autocross or have no stop policy for the po po with a older 5.0 car, until I did mine would trip at the worst of times. Use a rubber hammer and hit right under the drivers seat and you get a cool surprise too. What exactly triggers that crash relay? I believe the summit device is basically a Ford crash inertial relay (an enclosed suspended steel ball on a magnetic contact?). On my son's 5.0 Mustang hatch back, slamming the rear hatch hard would activate it, it was OEM mounted inches from the latch. On my cars its mounted on the firewall, an intended kick will activate it while I am exiting, and if that kick is during So Fla carjacking, the car will go maybe a block and tun out of gas in the middle of the next intersection, at least that is the plan. I have never been in a wreck in my cars with it.
#2488791
04/27/18 07:42 PM
04/27/18 07:42 PM
Porter67
Oh ok what kind of relay to get? Like a inline fuse type relay? I forget the PN but its a basic std relay, I mounted mine in the trunk and run the short big lead to the pumps. Same relays on my spal fans, I will look at the pn.
[Re: Porter67]
#2489032
04/28/18 12:39 PM
04/28/18 12:39 PM
Posts: 19,342 north of coder
moparx
Oh ok what kind of relay to get? Like a inline fuse type relay? I forget the PN but its a basic std relay, I mounted mine in the trunk and run the short big lead to the pumps. Same relays on my spal fans, I will look at the pn. i believe the call them an ISO relay. available at any parts store. has 4 or 5 pins. 30, 85, 86, and 87 [plus, on the 5 pin version, 87-A].
