Page 3 of 4 1 2 3 4
Re: Tools that have helped greatly [Re: WHITEDART] #2462294
03/06/18 10:49 PM
03/06/18 10:49 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Tools ....that is a tough one. I seem to work for tools.
Most used would be a toss up between the Tig welder and the coffee pot.
This is a handy tool that is always a pleasure to use www.amazon.com/Tajima-SLT-AL200M-Rotary-Dual-Scale-Magnetic/dp/B00023S4TO
"Just a Bracket car dressed up like a streetcar"
Re: Tools that have helped greatly [Re: Just-a-dart] #2462326
03/06/18 11:28 PM
03/06/18 11:28 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Another tool I would never want to go without. I strip and assemble a lot of heads and this makes the job so easy.
B1 Head by John Cadamore, on Flickr
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Tools that have helped greatly [Re: Just-a-dart] #2462380
03/07/18 01:17 AM
03/07/18 01:17 AM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
This is a tool that I picked up used.. Works amazing.. makes life easy when you got to change valve springs on motor.. I was hoping someone could identify the brand..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Tools that have helped greatly [Re: TRENDZ] #2462556
03/07/18 02:00 PM
03/07/18 02:00 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Originally Posted By TRENDZ
Eastwood tubing flare tool. Very rarely am I impressed by a tool. This thing never gives a bad flare. Use it with steel, nicad, and stainless. Perfect every time.
Just don't go king kong on the tool. I broke mine, cracked the back off where it holds the blocks. I think I can fix it by milling the back and attaching a steel plate to replace the part that holds the blocks in place.
Re: Tools that have helped greatly [Re: WHITEDART] #2462649
03/07/18 04:30 PM
03/07/18 04:30 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I don't know who made it. But I want one.
Re: Tools that have helped greatly [Re: WHITEDART] #2462813
03/07/18 09:56 PM
03/07/18 09:56 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
I bought one of these because it just looked cool and I can't resist tools anyway. I've only found one good application so far but it works great when dealing with the oil pump drive shaft.
Re: Tools that have helped greatly [Re: shorthorse] #2462817
03/07/18 10:03 PM
03/07/18 10:03 PM
PA.
"Little"John
"Little"John
PA.
That looks like a lethal weapon. Lol
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Tools that have helped greatly [Re: WHITEDART] #2462860
03/07/18 11:04 PM
03/07/18 11:04 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
These.
Kevin
Re: Tools that have helped greatly [Re: Twostick] #2462871
03/07/18 11:17 PM
03/07/18 11:17 PM
bean town ....Ca
W
W
bean town ....Ca
I was on a project where I noticed a couple plumbers. Using these.. they told me that they had been using them for 8 hours a day for several months.. I can tell you I picked one up.. and it's probably one of the most used tools in my garage.. most of my work is done in the evening or at night.. about 30 bucks from Amazon
Re: Tools that have helped greatly [Re: WHITEDART] #2462878
03/07/18 11:27 PM
03/07/18 11:27 PM
PA.
"Little"John
"Little"John
PA.
I bought a new workbench (storage unit) for clean head assembly and I was assorting all my engine and transmission tools and I found one tool I hope I NEVER have to use again. My old hand crank ring filer. LOL. I used to hate filing rings with that thing.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Tools that have helped greatly [Re: greendart408] #2462936
03/08/18 01:35 AM
03/08/18 01:35 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Originally Posted By greendart408
Lsm on the head valve spring compressor, once used you will appreciate.
I can't stop buying LSM tools. Light and effortless.
We just ordered a spring tester.
Re: Tools that have helped greatly [Re: Jeremiah] #2462940
03/08/18 01:44 AM
03/08/18 01:44 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
My list of fav's:
Gearwrench
Super Scraper
H-frame Press
Stationary belt sander
Sheet metal shear
Anything LSM
HF Transmission Jack (hard to admit that one )
Re: Tools that have helped greatly [Re: skrews] #2462979
03/08/18 04:40 AM
03/08/18 04:40 AM
Boise
thegodfather Offline
Boise
Originally Posted By skrews
Wide band air fuel ratio gauge.
Can you make a recommendation on this tool? Brand? Who has it? Thx
Re: Tools that have helped greatly [Re: Jeremiah] #2463040
03/08/18 12:34 PM
03/08/18 12:34 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
LSM stuff is great!
Re: Tools that have helped greatly [Re: thegodfather] #2463612
03/09/18 10:53 AM
03/09/18 10:53 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Personally I like the NGK setup because it works with NTK 02's and they are more lead tolerant than the Bosch sensors. Also a good reason why the Holley Dominator ECU is cool as it also support NTK.
NTK Wideband
Re: Tools that have helped greatly [Re: WHITEDART] #2463807
03/09/18 03:45 PM
03/09/18 03:45 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
My FAST EFI uses the NTK sensor is well
Re: Tools that have helped greatly [Re: WHITEDART] #2463981
03/09/18 08:51 PM
03/09/18 08:51 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
I bought an OTC tool a long while back,one of the best tools out there.
Re: Tools that have helped greatly [Re: Just-a-dart] #2464700
03/11/18 01:09 PM
03/11/18 01:09 PM
bean town ....Ca
W
W
bean town ....Ca
Originally Posted By Just-a-dart
Originally Posted By CMcAllister
Yeah, racing on credit is bad,bad,bad. I've seen guys roll in to the track with a nice rig and top shelf stuff and so broke they couldn't pay attention. Debit card ran as a credit card and tied to an account with enough to pay for the stuff, period. Or a card with cash back and the bill paid every month.
Man you and Al are missing up my plan for pulling a 2nd out on the house and doing a new Engine program To hang with Whitedart and Jay Waxler laugh2
what's a couple seconds amongst friends whistling
Re: Tools that have helped greatly [Re: WHITEDART] #2464711
03/11/18 01:24 PM
03/11/18 01:24 PM
KY
65pacecar Offline
65pacecar  Offline
KY
Gear wrench especially in tight spots, saved me OK n a Grand Am Starter in cold weather recently.
Mighty Vac for brake bleeding, works great amd a one man job now.
Re: Tools that have helped greatly [Re: pittsburghracer] #2464826
03/11/18 05:26 PM
03/11/18 05:26 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
I cringed when I bought it. After using it I wish I'd bought it years ago.
Page 3 of 4 1 2 3 4
