#2460973 - 03/04/18 02:10 PM chassis question
dbran451 Offline
Loc: ohio
looking at a mild steel chassis out of a 71 Dart will that work with out a ton of mods on our 69 dart
1.413 [Email]9.96@134.36[/Email]
#2461104 - 03/04/18 05:23 PM Re: chassis question [Re: dbran451]
sgcuda Offline
Loc: Charlotte, North Carolina
Are you talking full tube chassis? You would have to know the 71 Dart dimension vs your 69 and how close a fit the chassis is to the body walls. Lots of variables. You might slip your body right on, or you could end up chopping and welding for a very long time.
[image][/image]
#2461139 - 03/04/18 06:12 PM Re: chassis question [Re: dbran451]
CMcAllister Offline
Loc: Fulton County, PA
I have to believe that all of the '67-up Dart hardtop bodies are basically the same except the nose and tail. Glass, interior, carpet, suspension, that stuff is all interchangeable I believe.
If I didn't see this chassis with a body on it, I'd want to know who built it, did it certify, is it done correctly, etc. Sometimes, people pick up smoking deals on some of this stuff and spend more to make it work than if they built new from scratch.
#2461169 - 03/04/18 07:03 PM Re: chassis question [Re: CMcAllister]
Loc: Bend,OR USA
iagree
I bought a Alston Avenger chassis for a racer from a friend who had bought it from the guy that welded up the kit, he had use the wrong thickness(.069 where .083 should have been) tubing on the lower foot across the front and left door bar shruggy It would not SFI certify due to that whiney work
OP, make sure your getting something you can use scope thumbs
If your planning on going faster later, faster than 7.50 ET in the 1/4 mile, go with a all moly chassis now up
Edited by Cab_Burge (03/05/18 02:30 AM)
#2462284 - 03/06/18 07:37 PM Re: chassis question [Re: dbran451]
dbran451 Offline
Loc: ohio
thanks for the replies after getting some more pictures and seeing the welds we have decided to pas on this
25,351 Registered Members
190,290 Topics
Cuda vs Barracuda trim
by fastmark
Today at 07:08 AM
SPD on my AAR
by fastmark
Today at 06:24 AM
1969 Plymouth Road Runner n/a
by tomsjack
Today at 04:23 AM
Solid roller cam valve spring and lifter question
by Pockets
Today at 01:42 AM
