CM cage
#2462209
03/06/18 09:02 PM
03/06/18 09:02 PM
Posts: 1,432 Martinsville, IN
cdwmotorsports
Martinsville, IN
I currently have a MS cage in my Demon and am wanting to switch to a CM for smaller diameter bars. I have seen pics of cars with CM cages tied into the stock chassis and I am wondering how one does that. I can only presume the chassis is MS and that the CM cage is welded to it directly.
eBay-cdwmotorsports
Re: CM cage
[Re: cdwmotorsports]
#2462219
03/06/18 09:14 PM
03/06/18 09:14 PM
Posts: 4,562 Motor City
6PKRTSE
Motor City
Look at my "Coming To A Strip Near You 25.5 Challenger post. Obviously,mine is an E Body but same principle for your car. My chassis and full cage is all c.m. and is ran through all the stock floors and firewall.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: CM cage
#2462280
03/06/18 10:33 PM
03/06/18 10:33 PM
Posts: 11,501 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
You may have MS frame ties or you may be looking at getting it welded to stock floors or frame rails. That is acceptable, the rule says any weld that affects CM needs to be TIG. MS to CM, CM to MS and CM to CM are all TIGed. Beyond that, rules for construction are pretty much the same until you get to an SFI certified situation. The rule book is pretty detailed in it's requirements.
Also, using ChromeMoly instead of Mild Steel doesn't allow you to use smaller diameter bars. Just reduced wall thickness. Doing a cage instead of a bar allows you to use 1.625 instead of 1.750 diameter.
Re: CM cage
[Re: CMcAllister]
#2462523
03/07/18 01:08 PM
03/07/18 01:08 PM
6PKRTSE
Motor City
Another thing is resale. A moly car will always be able to bring more $$$ over a M.S. car due it being able to cert or re-cert & usually less weight when compared to the amount of bars each car would have.
Re: CM cage
[Re: polyspheric]
#2463548
03/09/18 02:35 AM
03/09/18 02:35 AM
cdwmotorsports
Martinsville, IN
No one reads anything but their own post. Actually I did read your post, and regarding your statement about roll bar vs cage being the determining factor in bar size. I appreciate the correction. I however currently have a cage so in this instance it does allow for me to go to a smaller diameter bar. Thanks for your original input
eBay-cdwmotorsports
Re: CM cage
#2463550
03/09/18 02:39 AM
03/09/18 02:39 AM
cdwmotorsports
Martinsville, IN
6PKRTSE, I have owned the car since 94, she ain’t going anywhere. Even if it only stays a street car. A lot of great people have helped me since I was a dumb 19 year old kid on this car and no less than two of them are no longer here.i have the trunk flooring and the windshield bars I want to change so now seems like the best time to change it all.
eBay-cdwmotorsports
Re: CM cage
[Re: polyspheric]
#2463773
03/09/18 03:15 PM
03/09/18 03:15 PM
Posts: 22,695 Bitopia
jcc
Bitopia
No one reads anything but their own post. Not always, especially when you have yourself on "ignore".
Re: CM cage
#2463791
03/09/18 03:35 PM
03/09/18 03:35 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
As pointed out the only thing to consider is where welding of moly is concerned is the moly tube HAS to be tig welded in place. You will see a minor weight savings from MS to Moly n a simple cage. It wont be a ton of weight to be sure but some. I also prefer outriggers over plates on the floor
Re: CM cage
[Re: dvw]
#2463793
03/09/18 03:35 PM
03/09/18 03:35 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I personally don't like installing a bar or cage on a 50 year old floor pan. Outriggers to a plated rocker make way more sense to me. Doug I've always preferred to do it this way. I like to use 2x3 and section it up into the floor, sit the bars onto - or into - it above the floor, tying the chassis, cage and floorpan all together. This as opposed to the outrigger being under the floor with the floor trimmed around the bars. The 2x3 can be mitered and made to fit nice and clean. Most people think this is too much work, but it makes the car safer and stiffer.
Re: CM cage
#2463814
03/09/18 03:58 PM
03/09/18 03:58 PM
Posts: 4,205 New York
polyspheric
New York
My point was that when people who weren't interested enough to post correct information assume that no one else has, they're just wasting my time.
My new rule: assume everyone already knows everything, and never makes mistakes. Yup, that'll work.
Boffin Emeritus
Re: CM cage
#2463831
03/09/18 04:19 PM
03/09/18 04:19 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
And a note on Mild Steel, it's not all the same. ERW is a welded seam tube, typically made from 1010 steel. It's cheap and the wall thickness is hit or miss, which is why people have to use heavy .134 wall stuff to make sure it passes tech.
DOM is much more accurate and typically made with 1020. Usually you can use .120 wall with a .118 minimum spec safely.
ERW is really crap. Running a drill bit through both materials really shows the difference in them. Both are considered mild steel, costs are different.
Re: CM cage
[Re: cudaman1969]
#2463952
03/09/18 08:15 PM
03/09/18 08:15 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Sheet metal is just hanging there, but like my inspector said, you have two cages, body and roll cage. Exactly. The formed sheet metal body is also a stiff and substantial structure. Use it. With some planning, the body and the new chassis/cage can be made to support and reinforce each other, making the assembly stronger than if the body was just along for the ride. Tie them together, beyond the mounting points called for to get the cage in the car, to create one assembly
