#2462024 - 03/06/18 12:14 PM Rear coilover spring replacement?
70satelliteguy Offline
Loc: Penna
Should these be replaced when replacing shocks?
Mine are about 6-7 years old and I am replacing my single adjustable shocks with double adjustable shocks.
Thanks Mike
#2462035 - 03/06/18 12:38 PM Re: Rear coilover spring replacement? [Re: 70satelliteguy]
Loc: Bend,OR USA
Has the cars rear ride height change since new? If so replace them, if not don't twocents
Are you happy with them now?
#2462040 - 03/06/18 12:55 PM Re: Rear coilover spring replacement? [Re: 70satelliteguy]
CMcAllister Offline
Loc: Fulton County, PA
If it has a lot of trailer miles or a few years of use, probably. My serious guys change them every 2 years, about 140 runs. Less if it's a light spring that is compressed some to store energy. Measure the free length. If it is a 12" spring, and it measures 11.875, it goes in the scrap.
#2462053 - 03/06/18 01:21 PM Re: Rear coilover spring replacement? [Re: CMcAllister]
Loc: Penna
Ride height has not changed . I will measure them when the come off and see if they still measure 12 in.
Thanks Mike
#2462130 - 03/06/18 03:49 PM Re: Rear coilover spring replacement? [Re: 70satelliteguy]
dvw Offline
Loc: MI, usa
Mine have 500 passes(130psi). Both are bent and we're rubbing severly on the shock body. Ride height never changed.
Doug
#2462155 - 03/06/18 04:35 PM Re: Rear coilover spring replacement? [Re: dvw]
Loc: Penna
Thanks DVW, will check mine to see if they are bent. Were there any signs that they were bent? Mine are also 130's and have lots of passes.
heavy car and trans brake.
Mike
25,630 Registered Members
195,575 Topics
Weird inconsistant studder in the engine
by Andrewh
12/13/18 10:12 AM
Original Mr. Norm’s T-Shirt
by floyd
12/13/18 09:58 AM
AAA roadside replacement battery?
by magnum440d100
12/13/18 09:27 AM
Save Money & Get Free Swag With SST’s Santa’s Swag Sale
by Rustymuscle
12/13/18 09:06 AM
