Page 2 of 2 < 1 2
#2462704 - 03/07/18 03:21 PM Re: Big block headers for duster [Re: ProSport]
493_DART Offline
Loc: Worst Weather USA
Originally Posted By ProSport
Originally Posted By 493_DART
I have the Hedman fenderwell race headers. Love them. Everything is easy to work on and i can have both headers out of the car in under 10 minutes
What size front tire are you running? Are you running an exhaust system?
Any pics?
#2462706 - 03/07/18 03:25 PM Re: Big block headers for duster [Re: ozymaxwedge]
493_DART Offline
Originally Posted By ozymaxwedge
A naked shot
Those are Hedman headers? They look like an excellent product! They almost look stainless? Did you hot, clear paint them somehow?
Yes Dave, Headman Headers straight out of the box uncoated , they have black ceramic coating now.
do you have a pic of where the collector bolts to the exhaust ? I thought about putting muffs on mine
#2462732 - 03/07/18 04:21 PM Re: Big block headers for duster [Re: 493_DART]
Dave Hall Offline
Loc: Cotati, CA
There's a pic at the bottom of the first page by Ozy...
#2462892 - 03/07/18 08:56 PM Re: Big block headers for duster [Re: 493_DART]
ozymaxwedge Offline
Loc: Australia
Only one I can find mate, We used a sharp bend from a (3.5"donut) to get it around the chassis rail
1963 Plymouth Max Wedge
1971 Barracuda
#2462896 - 03/07/18 09:03 PM Re: Big block headers for duster [Re: ozymaxwedge]
Sixpak Offline
Loc: The Swamp
Good lord, all the machinations you have to go thru on a right hand drive vehicle. To make matters worse the driveline offset makes it worse on a right hand drive car...
#2466181 - 03/13/18 11:58 PM Re: Big block headers for duster [Re: Cab_Burge]
mikeysmopars Offline
Loc: fresno ca
Originally Posted By Cab_Burge
Originally Posted By Derrick Payne
Has anybody used the ones Bob Mazzolini sells I hear there the same as the pro parts is this true
No, his have bigger primary tubes, Pro Parts where two inch, Maz are 2 1/8 shruggy
I bought a set of the original Pro Parts from Bill Bgashaw before he sold out and close the doors on Pro Parts for my 1969 GTS Dart 383 4 speed car, they don't fit worth a hoot on low decks with stock heads down
I called him about this and was told their for 440 motors in A bodies with stock heads, not low deck B motors whiney shruggy
I have a low deck big block with Indy heads and have had every fender well header made for these cars as I hate fighting headers on a race car.headman made great power but tire clearance was very limited. Went to hooker fender wells and we're ok but I needed a bigger tube header, went to Mazzolini propart header and made much more power but a pain to work on. I finally ponied up the money and had some made locally. 2 1/8 to 2 1/4, expensive but easy to work on every part of the engine and transmission and can now run a 27" tire. We
Founder and CEO of the Central Valley Mopar Drag Pack
#2466183 - 03/14/18 12:00 AM Re: Big block headers for duster [Re: mikeysmopars]
Loc: fresno ca
Collector
#2466624 - 03/14/18 08:11 PM Re: Big block headers for duster [Re: Derrick Payne]
Ari440 Offline
Loc: long island NY
Edited by Ari440 (03/14/18 08:14 PM)
1.39 9.85 - 137 mph
#2466626 - 03/14/18 08:18 PM Re: Big block headers for duster [Re: Derrick Payne]
Ari440 Offline
Loc: long island NY
1.39 9.85 - 137 mph
#2466809 - 03/15/18 08:25 AM Re: Big block headers for duster [Re: Derrick Payne]
ProSport Offline
Loc: Akron, Ohio
Mikeysmopars, your custom headers are awesome, and I know your car runs good with them!
Sassy Grass street Duster, best of 10.69 at 124 driven to the track with 3.23 gears, naturally aspirated on 93 octane.
#2468553 - 03/19/18 10:57 AM Re: Big block headers for duster [Re: ProSport]
Loc: fresno ca
Yep the headers made a big difference and then struggled putting the power down but has run 9.50 @140 with 1.27 60 in real good air.
#2468556 - 03/19/18 11:02 AM Re: Big block headers for duster [Re: mikeysmopars]
Loc: fresno ca
#2469721 - 03/21/18 12:39 PM Re: Big block headers for duster [Re: Derrick Payne]
ProSport Offline
Loc: Akron, Ohio
Very impressive Mike ^^^
#2469875 - 03/21/18 04:54 PM Re: Big block headers for duster [Re: mikeysmopars]
Dave Hall Offline
Loc: Cotati, CA
Mike! Were you at Sonoma the last couple weeks? I saw at one point that the corrected was something like -1,200 feet?
#2469884 - 03/21/18 05:01 PM Re: Big block headers for duster [Re: Dave Hall]
Loc: fresno ca
This pic was second week of February at Sanoma and the air was below sea level. I think the highest effective was was 200 feet. Normally run in Bakersfield and DA is usually 1500 to 3000 effective. I usually run 9.60s & 70s at home.
#2470923 - 03/23/18 11:22 AM Re: Big block headers for duster [Re: mikeysmopars]
Thumperdart Offline
Loc: State of confusion
Originally Posted By mikeysmopars
Collector
Add some tail pipe to those and you may be surprised at the improvement.......... thumbs
#2476226 - 04/02/18 04:21 PM Re: Big block headers for duster [Re: Derrick Payne]
RHB Offline
Loc: NE. Ohio, USA
IMO. The under the body headers look nice. They are the traditional fit. What they do do is put your pipes and collectors right next to the transmission providing a wonderful heater for your transmission. It also makes it nice and tight to get the starter in. Not to mention those nicely bloody knuckles you can get. Don't forget any electric lines that can melt and for those with a push button transmission you have to protect the shift cable from melting. In regards to a transmission blow shield you basically at this time have to run a hard cover. Which can not be installed with the engine and transmission bolted in place in the car (major work). Soft blankets can melt without proper insulation (I am working on this).
Fender well headers can limit front tire size and may rub a little. Generally not enough to effect steering control. The do get all the hot pipes away from your transmission. They do give you room to work on your transmission. Electric lines, shifting cables, and transmission fluid lines are out of danger from being melted. Soft transmission blankets can now be used more easily than a hard blank since you do not have to unbolt the transmission and engine to install them. robinhoodblankets.com makes the ultimate soft blanket for fender well header cars.
#2476450 - 04/02/18 07:23 PM Re: Big block headers for duster [Re: Derrick Payne]
ProSport Offline
Loc: Akron, Ohio
RHB that sounds like a great combo for my next build.
#2476468 - 04/02/18 07:40 PM Re: Big block headers for duster [Re: ProSport]
Edge Offline
Loc: Alberta Canada
Those custom fenderwell headers turned out great I was never a fan of the hooker fenderwell headers that I ran with my A body in the past.
76 Duster work in progress
Page 2 of 2 < 1 2
25,496 Registered Members
193,163 Topics
transmission fluid
by jonesboys
16 seconds ago
What crank pulley do I neet?
by gsmopar
7 minutes 55 seconds ago
When is the bigger U joint needed?
by radar
33 minutes 49 seconds ago
Silly Q- how are converter bolts so small?!
by radar
50 minutes 40 seconds ago
