Rear coilover spring replacement? #2462024
03/06/18 03:14 PM
03/06/18 03:14 PM
Penna
70satelliteguy Offline OP
Penna
Should these be replaced when replacing shocks?
Mine are about 6-7 years old and I am replacing my single adjustable shocks with double adjustable shocks.
Thanks Mike
Re: Rear coilover spring replacement? [Re: 70satelliteguy] #2462035
03/06/18 03:38 PM
03/06/18 03:38 PM
Has the cars rear ride height change since new? If so replace them, if not don't twocents
Are you happy with them now?
Re: Rear coilover spring replacement? [Re: 70satelliteguy] #2462040
03/06/18 03:55 PM
03/06/18 03:55 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
If it has a lot of trailer miles or a few years of use, probably. My serious guys change them every 2 years, about 140 runs. Less if it's a light spring that is compressed some to store energy. Measure the free length. If it is a 12" spring, and it measures 11.875, it goes in the scrap.
Re: Rear coilover spring replacement? [Re: CMcAllister] #2462053
03/06/18 04:21 PM
03/06/18 04:21 PM
Penna
Penna
Ride height has not changed . I will measure them when the come off and see if they still measure 12 in.
Thanks Mike
Re: Rear coilover spring replacement? [Re: 70satelliteguy] #2462130
03/06/18 06:49 PM
03/06/18 06:49 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine have 500 passes(130psi). Both are bent and we're rubbing severly on the shock body. Ride height never changed.
Doug
Re: Rear coilover spring replacement? [Re: dvw] #2462155
03/06/18 07:35 PM
03/06/18 07:35 PM
Penna
Penna
Thanks DVW, will check mine to see if they are bent. Were there any signs that they were bent? Mine are also 130's and have lots of passes.
heavy car and trans brake.
Mike
