#2461993 - 03/06/18 10:57 AM 05 300C oil pressure sensor
TMBOOTS Offline
Loc: upstate NY 12839
Can that sensor be checked without removing it..Check engine light is on..Code P0520 shows up near the speedometer when I checked the code using the key switch..Any advise appreciated..
#2462002 - 03/06/18 11:11 AM Re: 05 300C oil pressure sensor [Re: TMBOOTS]
68Cbarge Offline
Loc: Canuckville
Common issue...just replace it with an O.E sensor.
I had issues with aftermarket replacement sensors.
The sensor is n a bit of a tight spot,but can be done.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
#2464462 - 03/10/18 06:06 PM Re: 05 300C oil pressure sensor [Re: 68Cbarge]
TMBOOTS Offline
Thanks for your input..Did the job this AM and have been running the car most of the day, and engine light is not on..It took some time and 3 band-aids...WELL WORTH IT
25,344 Registered Members
190,219 Topics
D100 Fenderwelll Headers
by 6pakdakota
06/21/18 01:35 AM
Silver Sport's T56 perfect fit kit shifter relocation
by 71_dramaqueen
06/21/18 01:27 AM
R/T rear valance brace, Challenger
by 71_dramaqueen
06/21/18 12:59 AM
WIW 1999 Ramburban
by dodgedon
06/21/18 12:23 AM
