#2461993 - 03/06/18 10:57 AM 05 300C oil pressure sensor
TMBOOTS Offline
Loc: upstate NY 12839
Can that sensor be checked without removing it..Check engine light is on..Code P0520 shows up near the speedometer when I checked the code using the key switch..Any advise appreciated..
#2462002 - 03/06/18 11:11 AM Re: 05 300C oil pressure sensor [Re: TMBOOTS]
68Cbarge Offline
Loc: Canuckville
Common issue...just replace it with an O.E sensor.
I had issues with aftermarket replacement sensors.
The sensor is n a bit of a tight spot,but can be done.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
#2464462 - 03/10/18 06:06 PM Re: 05 300C oil pressure sensor [Re: 68Cbarge]
TMBOOTS Offline
Thanks for your input..Did the job this AM and have been running the car most of the day, and engine light is not on..It took some time and 3 band-aids...WELL WORTH IT
25,631 Registered Members
195,640 Topics
How I keep track of my "Barn Finds"
by Devil
12/14/18 11:43 PM
361 bb stroker
by orange elephants
12/14/18 10:57 PM
charger Rallye dash cluster bulb locations
by lockjaw-express
12/14/18 10:42 PM
boarding my garage
by Superfreak
12/14/18 09:47 PM
