#2461503 - 03/05/18 12:12 PM Simple question , Valve springs suggestions for a stock RB
polarconvert Offline
Loc: Janesville, WI
I am pulling my stock 70k mile 383 4V, RV cammed heads. I want to replace the valve springs and seals. What would you suggest I use and where is a good place to purchase them? thanks for your help.
#2461515 - 03/05/18 12:30 PM Re: Simple question , Valve springs suggestions for a stock RB [Re: polarconvert]
Steve1118 Offline
Loc: Walton's Mountain, Pa
If it's a stocker, just go to the local auto parts store and order a factory replacement.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
#2461580 - 03/05/18 02:43 PM Re: Simple question , Valve springs suggestions for a stock RB [Re: polarconvert]
Loc: Bend,OR USA
Any decent cam company springs for a B/RB Mopar cam with up to .525 lift should work fine, I shoot for 125 Lbs. minimum on the seats and from 300 to 350 lbs. opened at .484 lift on the valves up scope
Some of the cheaper over the counter auto part stores replacement valve springs aren't worth having or using down twocents
#2461640 - 03/05/18 05:01 PM Re: Simple question , Valve springs suggestions for a stock RB [Re: Cab_Burge]
qwkmopardan Offline
Loc: Affton MO
911-16 comp cams springs. $94 at summit.
#2461928 - 03/06/18 08:29 AM Re: Simple question , Valve springs suggestions for a stock RB [Re: polarconvert]
polyspheric Offline
Loc: New York
Unless your 383 is nearly 60 years old, it's not an RB.
For springs it doesn't matter but it's relevant elsewhere.
Boffin Emeritus
25,346 Registered Members
190,219 Topics
CARBON FIBER HOOD
by A/MP
06/22/18 12:22 AM
TUNING W2 HEADS
by A/MP
06/22/18 12:15 AM
727 clutch pressure plate gap newb question
by radar
06/22/18 12:01 AM
Dakota clip- who has done and retained the EFI?
by CrAzYMoPaRGuY
06/21/18 11:26 PM
