A - body Spring relocation and flex ??? #2461358
03/05/18 09:15 AM
03/05/18 09:15 AM
SC
BowtieKillr Offline OP
SC
? , I got the car on jack stands ,level and the rear compartment supported.
I have removed the wheel tubes completly and cut the lip off the frame rails to provide that little bit of extra tire clearence. I went back and welded the rails back together where I removed the lip. I cut the rails at the front spring support and installed the leaf spring boxes and welded them in. I even beefed it up some where they go in. I installed new quarter skins before doing the rails and the quarters fit and turned out very nice and straight.
Now i can push down at the trunk jamb around the hinge area and I can see some flexing of the rear compartment. I can see the quarter skins flexing just a little at the tire opening. I cant move it much but there is some flexing that is noticed.
Roll bars are comming . I hope this is normal and the bars will make it more ridged.
Just wanting to know before continuing own.
Re: A - body Spring relocation and flex ??? [Re: BowtieKillr] #2461375
03/05/18 10:11 AM
03/05/18 10:11 AM
Michigan Detroit area
Doc Schwarz Offline
Doc Schwarz  Offline
Do you still have the X brace under the rear window?
Re: A - body Spring relocation and flex ??? [Re: Doc Schwarz] #2461376
03/05/18 10:17 AM
03/05/18 10:17 AM
SC
SC
No Doc I removed it years ago when I did the Small tire mini tubb. You think the roll cage that ties to the rear rails and a x brace would be good.
Re: A - body Spring relocation and flex ??? [Re: BowtieKillr] #2461535
03/05/18 04:19 PM
03/05/18 04:19 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Are the sub frames tied together? Before doing any other mods to the car, that would have been the first I'd have done. I'd also re-add the x brace behind the back seat. The roll bar ties into the frame rails but not into the sheet metal, whereas the x brace does by supporting the package tray and all the sheet metal that ties into it.
Re: A - body Spring relocation and flex ??? [Re: BowtieKillr] #2461635
03/05/18 07:40 PM
03/05/18 07:40 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Are the trunk hinges tied to the tubs?
Doug
Re: A - body Spring relocation and flex ??? [Re: Sixpak] #2461892
03/06/18 08:32 AM
03/06/18 08:32 AM
SC
SC
yes it has subframe connectors. Im Sure its just because I have everything out of it and theres not much supporting it .Ive got it all supported and level so ill weld in some bracing for the package tray and get the tubbs in and welded in and then the bars. I'm pretty sure it will be fine after that . Thanks
Re: A - body Spring relocation and flex ??? [Re: dvw] #2461893
03/06/18 08:32 AM
03/06/18 08:32 AM
SC
SC
Fixing to be !!
