Cam recommendations
#246169
03/07/09 08:23 PM
03/07/09 08:23 PM
What roller cam would you guys recommend for a 500 ci with the following parts.Also how hard should a guy rev something like this. Ported 440-1 heads 13.8 compression lighweight flattops Rons flying toilet 6000 converter 3000 lb race weight indy intake Eagle crank and rods
Re: Cam recommendations
[Re: DemonDust]
#246172
03/08/09 08:52 AM
03/08/09 08:52 AM
How about more specs. Bore, stroke, head flow, valve sizes.
Sorry but this is my neighbors hodge podge of parts.As for the bore it is a .030 over 440 block with a girdle.The heads hav,nt been on a flow bench,so i have no idea on what they flow.Valves are the originals that indy supplied with the heads.He has talked to several cam companies and they all recommend running something different and this has him confused.Myself i,ve never run alcohol so i have no idea what kind of centerline he needs or duration. He said they mentioned that he would need a cam with a centerline of 112 or greater to use with injection.
#246173
03/08/09 09:40 AM
03/08/09 09:40 AM
Posts: 656 Kokomo, IN
540dust
Kokomo, IN
The best I can do, never ran a roller before.
