#2461001 - 03/04/18 02:54 PM 92 Dodge van speedometer not working
Hugh Jorgan Offline
Loc: Wills Point, Texas
I have a 92 B250 cargo van 5.2 MPI/auto that the speedometer quit working. Electric speedo/no cable. The odometer DOES work as well as the cruise control. I replaced the speed sensor on the transmission, but no luck.
Any ideas?
Thanks in advance.
#2461039 - 03/04/18 04:15 PM Re: 92 Dodge van speedometer not working [Re: Hugh Jorgan]
buildanother Offline
Loc: chicagoland,usa
Had a few speedos of that era take a dump at higher miles on some rams and ramchargers. Must be common. I would think that new ones are possibly discontinued.
#2461116 - 03/04/18 05:41 PM Re: 92 Dodge van speedometer not working [Re: buildanother]
bboogieart Offline
Loc: Lost and Spaced
Just a guess.
Being the odo and cruise works, I believe the speedo gauge itself needs to be repaired or replaced.
I have mechanical Aptitude.
I can screw up anything.
#2461144 - 03/04/18 06:20 PM Re: 92 Dodge van speedometer not working [Re: Hugh Jorgan]
RamblerMan Offline
Loc: Castlegar, BC, Canada
Two things to check. Now, I'm not particularly intimate with the Dodge van, but a lot of mopar products of this era have a speedometer that "plugs in" to the printed circuit board. The "plugs" look eerily similar to the pins on the back of our 70's-era gauge clusters, but are much longer.
I've seen these pins get corroded and since they are longer, they can also break off losing contact with the PCB. IIRC, it takes three or four pins to run the speedohead, if one breaks, the odo will still work, but the speedo may not. (or vice versa)
Check that first, but failing that, you may need a new speedo.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
#2461285 - 03/04/18 10:40 PM Re: 92 Dodge van speedometer not working [Re: RamblerMan]
Mr. Smurf Offline
Loc: Mid Michigan
Probably the drive motor for the speedo, my 92 ctd has issues once in a while.
Should be repairable.
Google "GM speedometer problems", huge recall on them. Mopar might have used the same supplier.
Ed
#2461465 - 03/05/18 10:52 AM Re: 92 Dodge van speedometer not working [Re: Mr. Smurf]
qwkmopardan Offline
Loc: Affton MO
I have had problems with the odometer quitting but the speedometer still works. Problem is a little 14 tooth plastic gear, the dia. of a pencil eraser, loses some or all of the teeth. The gear can be bought on feeBay. Maybe something similar makes the speedo work???
#2461494 - 03/05/18 12:02 PM Re: 92 Dodge van speedometer not working [Re: qwkmopardan]
Hugh Jorgan Offline
I will probably install an aftermarket GPS speedometer for the time being so it will pass a safety inspection to get the tags renewed. Will look for another factory unit in the local yards.
Thanks for the replies!
#2461616 - 03/05/18 03:51 PM Re: 92 Dodge van speedometer not working [Re: Hugh Jorgan]
Hugh Jorgan Offline
I just called a place that does safety inspections and they tell me that a functioning speedometer is not necessary to pass the inspection. I didn't know that.
#2461618 - 03/05/18 04:00 PM Re: 92 Dodge van speedometer not working [Re: Hugh Jorgan]
68Cbarge Offline
Loc: Canuckville
I had a 66 300 with the infamous non-functioning speedo.
All the screws face the firewall.
I use a GPS stuck to the windshield...Done.AND passed inspection.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
25,629 Registered Members
195,568 Topics
California going to tax per text message
by pittsburghracer
Yesterday at 11:49 PM
Roll call: 2019 A12 50 YR Lift Off Reunion at Carlisle
by kevin69bman
Yesterday at 10:55 PM
New to the Gen3
by PS Arrow
Yesterday at 10:53 PM
904 nearly there....
by hysteric
Yesterday at 10:38 PM
