8 3/4/stock axles/spool in a D100 - will it live long? #2461227
03/04/18 11:55 PM
03/04/18 11:55 PM
Central US
grancuda Online content OP
grancuda  Online Content OP
Central US
Put a '72 D100 together & the only third member I have laying around at the moment is a 3.90 with a spool. I'm going to daily the thing for a while & it may be a month or so before I get it swapped. What's the chances of snapping an axle? I've got the tires pumped up to 40 psi so they don't hook up as good & hopefully spin easier & I try to make all my turns wide & take the straightest paths through parking lots. Got a line on a 3.55 open but it's going to need gone through.
1967 Barracuda Formula S 383
1967 Chevy C10 Short Stepper
1980 Macho Power Wagon LWB 318
2021 Toyota Supra
Re: 8 3/4/stock axles/spool in a D100 - will it live long? [Re: grancuda] #2461239
03/05/18 12:08 AM
03/05/18 12:08 AM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I've run a spool on street an I think It matters how big your tires are and how you drive. I would power up slitly on turns to help one tire slip
Have a great day
Iowan
"obsolete is neat"
Re: 8 3/4/stock axles/spool in a D100 - will it live long? [Re: Iowan] #2461242
03/05/18 12:14 AM
03/05/18 12:14 AM
okla.
sam64 Offline
sam64  Offline
okla.
30 spline axles on a pickup should last forever,not enough weight back there.
Re: 8 3/4/stock axles/spool in a D100 - will it live long? [Re: grancuda] #2461304
03/05/18 02:04 AM
03/05/18 02:04 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I ran an 8 3/4 with stock axles and a spool with drag radials in the 11's for a couple years and at least 100 passes before swapping to a 35 spline spool and after market axles. The stock axles showed no signs of stress when I took them out. They are tough indeed.
Re: 8 3/4/stock axles/spool in a D100 - will it live long? [Re: grancuda] #2461507
03/05/18 03:15 PM
03/05/18 03:15 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I still have stock axles in my 63. I run 4.30's with a Detroit Locker and 30 x 9 radial slicks on the street. I have 7 years on them on the street with my 493 and about 20 track passes and last time I had the axles out they still looked fine. I plan to upgrade but so far they have held up better then I thought they would. Course my car is an auto car. Ron
Re: 8 3/4/stock axles/spool in a D100 - will it live long? [Re: grancuda] #2461544
03/05/18 04:31 PM
03/05/18 04:31 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Ran 4:30s in a 75 D100 440 4 speed , stock axles and spool for about 5 years(28k miles) , ran those old Mickey Thompson I tread tires on the street.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: 8 3/4/stock axles/spool in a D100 - will it live long? [Re: grancuda] #2461695
03/05/18 09:55 PM
03/05/18 09:55 PM
michigan
6pakdakota Offline
6pakdakota  Offline
michigan
I daily drove a 360 Dakota for several years with a spool, 3.91 gears, and stock axles. No issues. The axles still looked perfect when the rear end came out of the truck.
