Re: Which street drag tires?
[Re: ScottSmith_Harms]
#2464799
03/11/18 04:07 PM
03/11/18 04:07 PM
Posts: 5,283 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
I have driven hundreds and hundreds of street miles on QTP’s nice tires The 28 by 11.5( 28 by 10 wide) fits nicely on a Demon/ Duster with correct backspace wheel. What offset/backspace are your wheels? Stock axle width? X2
Plymouth Makes It!
[Re: hemi-itis]
#2464923
03/11/18 09:00 PM
03/11/18 09:00 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
I am curious if ANY of you with over 500 HP can hook from a dead stop??? I have ET Street R's bias and I cant hook down low whatsoever.I av roll out in 1st and short shift 2nd then roll into it hard so 2/3s of the way through 2nd I'm at WOT then click high and stay hooked,,,most of the time. Also use 31 X 16.5's. Ay the track I use 10.5w M\T and they work very good My 517 C.I. six pack piump gas motor made over 600 HP to the flywheel and 545HP to the rear tires on a dyno jet chassis dyno here in Bend several years back, The M/T 13x31x15 ET street bias tires would almost dead hook at 9.0 lbs. on 10 inch wide wheels on my old Duster on the street, 1/2 to 3 turns max weighing 3450 Lbs. total ready to race with 50.7 % weight on the front tires I raced it with all three sets of tires on the car, the bias plies 13x31x15 ET street tires where the slowest ET and MPH at the track and the 315x60x15 M/T ET Street Radials ET and MPH where almost identical to the 10.5x31x15 M/T drag race slicks, the car would cross the finish line at 6500 RPM at 134.+ MPH with the slicks and cross at 7000 RPM with the ET Street Radials at almost the same MPH and ET I never drove that car with slicks on the road so no input about that I do like the M/T ET Street bias ply tires better on the street with decent HP compared to the M/T ET Street radials I used
[Re: RoadRunnerLuva]
#2465149
03/12/18 12:06 PM
03/12/18 12:06 PM
Posts: 11,701 Portage,michigan
B3422W5
Portage,michigan
I have driven hundreds and hundreds of street miles on QTP’s nice tires The 28 by 11.5( 28 by 10 wide) fits nicely on a Demon/ Duster with correct backspace wheel. What offset/backspace are your wheels? Stock axle width? X2 28 by 11.5 QTP..... 15 by 10 wheel with 4.5 backspace. This on a 70 Duster, super stock springs in stock location
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: mopar dave]
#2465177
03/12/18 01:03 PM
03/12/18 01:03 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Do those fit inside stock wheel houses?
#2465207
03/12/18 02:23 PM
03/12/18 02:23 PM
B3422W5
Portage,michigan
Do those fit inside stock wheel houses? Yes. It had been a while since i had that car( 70 b3 duster with W5 motor, many members here know the car) If you want to see what the tires look like on it..... go to youtube.....” don’s wheelstand” You can see how the tires fit. They were Just barely inside the wheel lips. Again 10 inch wheel in the video, so tire lays out more than wgen i had 8 inch wheels on it several years earlier With more backspace tire would rub to inside on s/s springs. Its important tire is centered in wheelwell
