#2461209 - 03/04/18 08:23 PM '75 D300 leaf spring question
blaze Offline
Loc: South-east Mn
Is a visual inspection adequate for the leaf springs? As long as they're no cracks or broken or missing leaves are they good to go?
#2461287 - 03/04/18 10:43 PM Re: '75 D300 leaf spring question [Re: blaze]
poorboy Offline
Loc: Freeport IL USA
The springs can be weak without being broken. Are they sagging? The top set of springs are the overloads and do not normally make contact with the brackets unless the truck has a pretty big load on it. It appears the overloads have recently been against the brackets by the discoloration of the rust on the brackets. If they would have been in contact a lot, the surface would have been shinny or not as rusty.
Have you recently put a heavy load (larger then normal) on the truck?
Springs tend to break at the center bolt, or at the edges near the U bolts. I would look pretty carefully.
A 75 is getting pretty old, if you believe those are the original springs, I think I would replace them. It looks like your changing the rear axle, replace the springs as well. Gene
25,631 Registered Members
195,639 Topics
361 bb stroker
by orange elephants
12/14/18 10:57 PM
charger Rallye dash cluster bulb locations
by lockjaw-express
12/14/18 10:42 PM
boarding my garage
by Superfreak
12/14/18 09:47 PM
55 DeSoto
by moparjack44
12/14/18 08:56 PM
