Page 1 of 4 1 2 3 4
Tools that have helped greatly #2461266
03/05/18 12:49 AM
03/05/18 12:49 AM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
I thought it would be great to start a thread.. where we could share.. info on tools that have made life easier.. I think whether they're store boughten.. or custom made.. I'm always in the quest for looking for an easier or better way..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Tools that have helped greatly [Re: WHITEDART] #2461268
03/05/18 12:55 AM
03/05/18 12:55 AM
bean town ....Ca
W
W
bean town ....Ca
I was recently at a shop and got to use one of these.. on mine I installed the 20 on one side and the 25 on the other... it feels good in the hand and is very helpful.. made lashing the valves so much easier.. actually gave them out for Christmas to a couple buddies.. this is just an internet pick of one identical to the one I am using. I think they are about 40 bucks up
Re: Tools that have helped greatly [Re: WHITEDART] #2461269
03/05/18 12:56 AM
03/05/18 12:56 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Stud Extractor.
I found mine hidden in a drawer in my tool box 10 minutes AFTER a half hour under my car in a wrestling match using a pipe wrench and channel locks to get a pair of block to bell housing locating pins out. I got them out but that SUCKED!!!!!!! Stud extractor would have made it a breeze.
Re: Tools that have helped greatly [Re: WHITEDART] #2461271
03/05/18 12:58 AM
03/05/18 12:58 AM
Kirkland, Washington
Pacnorthcuda Offline
MIG Welder. Waited till I was about 35 before buying one. Don't know how I got by without.
Re: Tools that have helped greatly [Re: Pacnorthcuda] #2461275
03/05/18 01:21 AM
03/05/18 01:21 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Flowbench. I bought two and then I built one and it set up exactly how I wanted it. It has taught me so much over the years
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Tools that have helped greatly [Re: pittsburghracer] #2461280
03/05/18 01:33 AM
03/05/18 01:33 AM
oregon
greendart408 Offline
oregon
Lsm on the head valve spring compressor, once used you will appreciate.
Re: Tools that have helped greatly [Re: WHITEDART] #2461282
03/05/18 01:36 AM
03/05/18 01:36 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Bead blast cabinet. Can't imagine having to wire brush everything. Rims, nuts and bolts, old tools, parts of all sorts. 1/2 of what we do working on or restoring stuff is cleaning just to get it to a state where we can begin that process.
Re: Tools that have helped greatly [Re: WHITEDART] #2461291
03/05/18 01:51 AM
03/05/18 01:51 AM
Washington
skrews Offline
skrews  Offline
Washington
Wide band air fuel ratio gauge.
Re: Tools that have helped greatly [Re: WHITEDART] #2461297
03/05/18 01:55 AM
03/05/18 01:55 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
Mig welder, dial caliper, battery powered impact driver, air compressor, belt sander, portable band saw, and my latest favorite tool, a welding table - which I made with the majority of the previously mentioned tools:
Re: Tools that have helped greatly [Re: WHITEDART] #2461352
03/05/18 08:37 AM
03/05/18 08:37 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
^^^That looks nice^^^ coffee
Re: Tools that have helped greatly [Re: WHITEDART] #2461356
03/05/18 09:09 AM
03/05/18 09:09 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Eastwood tubing flare tool. Very rarely am I impressed by a tool. This thing never gives a bad flare. Use it with steel, nicad, and stainless. Perfect every time.
Re: Tools that have helped greatly [Re: WHITEDART] #2461379
03/05/18 10:21 AM
03/05/18 10:21 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Does it have a feature that bonks you on the head and reminds you to put the flare nut on?
68 Barracuda Formula S 340
Re: Tools that have helped greatly [Re: WHITEDART] #2461401
03/05/18 11:44 AM
03/05/18 11:44 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I had thought that the battery impact was the handiest thing I had found in a long time. Until I found the battery ratchet.
It's even handier because I use it much more often than the impact. Plus it has a little light which I felt, at first, was gimmicky. But, it really helps these old eyes.
Master, again and still
Re: Tools that have helped greatly [Re: WHITEDART] #2461425
03/05/18 12:45 PM
03/05/18 12:45 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Mig welder, stationary belt sander, angle grinder, vise.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Tools that have helped greatly [Re: FurryStump] #2461438
03/05/18 01:00 PM
03/05/18 01:00 PM
bean town ....Ca
W
W
bean town ....Ca
This is one of those tools that I've always just had hanging around.. weather I'm doing valve spring keepers or reaching for a washer or not that I've dropped.. it seems as though this is one of the tools that I find myself using more and more.. typically can be found at your local auto parts store or Grainger for around 10$
Re: Tools that have helped greatly [Re: WHITEDART] #2461447
03/05/18 01:28 PM
03/05/18 01:28 PM
moparx Offline
moparx  Offline
don't forget the "grabber" tool thingy to go along with the magnet thingy.
beer
Re: Tools that have helped greatly [Re: WHITEDART] #2461462
03/05/18 01:49 PM
03/05/18 01:49 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Re: Tools that have helped greatly [Re: WHITEDART] #2461483
03/05/18 02:35 PM
03/05/18 02:35 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My Streamlight Stylus Pro Penlight.
Re: Tools that have helped greatly [Re: WHITEDART] #2461506
03/05/18 03:14 PM
03/05/18 03:14 PM
AndyF Offline
AndyF  Offline
I just built this cart setup using the US Car Tool body wheel kit. Adding the cross bars made the whole thing taller and more rigid. Now I move the car around in the shop to work on it and even roll it outside for dirty work.
Re: Tools that have helped greatly [Re: skrews] #2461511
03/05/18 03:24 PM
03/05/18 03:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
iagree This has been the most important tool for carb tuning and has made my life and others much easier.......... thumbs
Page 1 of 4 1 2 3 4
