Page 1 of 4 1 2 3 4 >
#2461266 - 03/04/18 09:49 PM Tools that have helped greatly
WHITEDART Offline
Loc: bean town ....Ca
I thought it would be great to start a thread.. where we could share.. info on tools that have made life easier.. I think whether they're store boughten.. or custom made.. I'm always in the quest for looking for an easier or better way..
In the 8s N/A.with Brett miller W8's
5.42 8.52 159.
#2461268 - 03/04/18 09:55 PM Re: Tools that have helped greatly [Re: WHITEDART]
WHITEDART Offline
I was recently at a shop and got to use one of these.. on mine I installed the 20 on one side and the 25 on the other... it feels good in the hand and is very helpful.. made lashing the valves so much easier.. actually gave them out for Christmas to a couple buddies.. this is just an internet pick of one identical to the one I am using. I think they are about 40 bucks up
5.42 8.52 159.
#2461269 - 03/04/18 09:56 PM Re: Tools that have helped greatly [Re: WHITEDART]
ScottSmith_Harms Offline
Mr Wizzard
Loc: Spokane Washington
Stud Extractor.
I found mine hidden in a drawer in my tool box 10 minutes AFTER a half hour under my car in a wrestling match using a pipe wrench and channel locks to get a pair of block to bell housing locating pins out. I got them out but that SUCKED!!!!!!! Stud extractor would have made it a breeze.
#2461271 - 03/04/18 09:58 PM Re: Tools that have helped greatly [Re: WHITEDART]
Pacnorthcuda Offline
Loc: Kirkland, Washington
MIG Welder. Waited till I was about 35 before buying one. Don't know how I got by without.
#2461275 - 03/04/18 10:21 PM Re: Tools that have helped greatly [Re: Pacnorthcuda]
pittsburghracer Offline
"Little"John
Loc: PA.
Flowbench. I bought two and then I built one and it set up exactly how I wanted it. It has taught me so much over the years
1970 Duster
Edelbrock headed 408
6.143@110.85 mph
9.73@135.05 mph shifting at 6700 RPM
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Untitled by John Cadamore, on Flickr
#2461280 - 03/04/18 10:33 PM Re: Tools that have helped greatly [Re: pittsburghracer]
greendart408 Offline
Loc: oregon
Lsm on the head valve spring compressor, once used you will appreciate.
#2461282 - 03/04/18 10:36 PM Re: Tools that have helped greatly [Re: WHITEDART]
Sixpak Offline
Loc: The Swamp
Bead blast cabinet. Can't imagine having to wire brush everything. Rims, nuts and bolts, old tools, parts of all sorts. 1/2 of what we do working on or restoring stuff is cleaning just to get it to a state where we can begin that process.
#2461291 - 03/04/18 10:51 PM Re: Tools that have helped greatly [Re: WHITEDART]
skrews Offline
Loc: Washington
Wide band air fuel ratio gauge.
#2461297 - 03/04/18 10:55 PM Re: Tools that have helped greatly [Re: WHITEDART]
humpty Offline
Loc: Minnesota, USA
Mig welder, dial caliper, battery powered impact driver, air compressor, belt sander, portable band saw, and my latest favorite tool, a welding table - which I made with the majority of the previously mentioned tools:
72 Duster - 408ci W2, 10.18@131, 6.31@110.
https://m.youtube.com/watch?v=Q4P51j38-MI
#2461352 - 03/05/18 05:37 AM Re: Tools that have helped greatly [Re: WHITEDART]
racerx Offline
Loc: Mo.
^^^That looks nice^^^ coffee
Edited by racerx (03/05/18 05:38 AM)
#2461356 - 03/05/18 06:09 AM Re: Tools that have helped greatly [Re: WHITEDART]
TRENDZ Offline
Loc: Milwaukee WI
Eastwood tubing flare tool. Very rarely am I impressed by a tool. This thing never gives a bad flare. Use it with steel, nicad, and stainless. Perfect every time.
#2461379 - 03/05/18 07:21 AM Re: Tools that have helped greatly [Re: WHITEDART]
Bad340fish Offline
Loc: Tulsa OK
Does it have a feature that bonks you on the head and reminds you to put the flare nut on?
68 Barracuda Formula S 340
#2461401 - 03/05/18 08:44 AM Re: Tools that have helped greatly [Re: WHITEDART]
DaveRS23 Offline
Loc: Benton, IL.
I had thought that the battery impact was the handiest thing I had found in a long time. Until I found the battery ratchet.
It's even handier because I use it much more often than the impact. Plus it has a little light which I felt, at first, was gimmicky. But, it really helps these old eyes.
KOS
#2461425 - 03/05/18 09:45 AM Re: Tools that have helped greatly [Re: WHITEDART]
FurryStump Offline
Loc: Connecticut
Mig welder, stationary belt sander, angle grinder, vise.
best of 11.83 @ 116 mph 68 340 formula s fastback,Money delete option,Supercar shootout stock appearing.
#2461438 - 03/05/18 10:00 AM Re: Tools that have helped greatly [Re: FurryStump]
WHITEDART Offline
This is one of those tools that I've always just had hanging around.. weather I'm doing valve spring keepers or reaching for a washer or not that I've dropped.. it seems as though this is one of the tools that I find myself using more and more.. typically can be found at your local auto parts store or Grainger for around 10$
5.42 8.52 159.
#2461447 - 03/05/18 10:28 AM Re: Tools that have helped greatly [Re: WHITEDART]
moparx Offline
Dreaming of implants
Loc: north of coder
don't forget the "grabber" tool thingy to go along with the magnet thingy.
beer
#2461462 - 03/05/18 10:49 AM Re: Tools that have helped greatly [Re: WHITEDART]
Al_Alguire Offline
Loc: Las Vegas
#2461483 - 03/05/18 11:35 AM Re: Tools that have helped greatly [Re: WHITEDART]
justinp61 Offline
Loc: W. Kentucky
My Streamlight Stylus Pro Penlight.
#2461506 - 03/05/18 12:14 PM Re: Tools that have helped greatly [Re: WHITEDART]
AndyF Online   content
Loc: Oregon
I just built this cart setup using the US Car Tool body wheel kit. Adding the cross bars made the whole thing taller and more rigid. Now I move the car around in the shop to work on it and even roll it outside for dirty work.
#2461511 - 03/05/18 12:24 PM Re: Tools that have helped greatly [Re: skrews]
Thumperdart Offline
Loc: State of confusion
iagree This has been the most important tool for carb tuning and has made my life and others much easier.......... thumbs
Edited by Thumperdart (03/05/18 12:24 PM)
25,635 Registered Members
195,669 Topics
Barracuda Grill Surrounds
by 65pacecar
12/16/18 12:09 PM
Link to my demon
by dem0n72
12/16/18 12:09 PM
Good deal on '74 set of engine decals 440-RB $40 free shpng
by larrymopar360
12/16/18 12:05 PM
how deep a hole should 4 speed crank be
by moparpro
12/16/18 11:33 AM
