#2461227 - 03/04/18 08:55 PM 8 3/4/stock axles/spool in a D100 - will it live long?
grancuda Offline
Loc: Central US
Put a '72 D100 together & the only third member I have laying around at the moment is a 3.90 with a spool. I'm going to daily the thing for a while & it may be a month or so before I get it swapped. What's the chances of snapping an axle? I've got the tires pumped up to 40 psi so they don't hook up as good & hopefully spin easier & I try to make all my turns wide & take the straightest paths through parking lots. Got a line on a 3.55 open but it's going to need gone through.
1967 Barracuda Formula S 383
1969 Dart Custom 2dr HT 440
1972 D1oo SWB 360
1980 Macho Power Wagon LWB 318
2010 Ford Raptor 6.2L
#2461239 - 03/04/18 09:08 PM Re: 8 3/4/stock axles/spool in a D100 - will it live long? [Re: grancuda]
Iowan Offline
Loc: Lost in Time
I've run a spool on street an I think It matters how big your tires are and how you drive. I would power up slitly on turns to help one tire slip
Have a great day
Iowan
"obsolete is neat, the older I get the better I was"
#2461242 - 03/04/18 09:14 PM Re: 8 3/4/stock axles/spool in a D100 - will it live long? [Re: Iowan]
sam64 Offline
Loc: okla.
30 spline axles on a pickup should last forever,not enough weight back there.
10.86@123
#2461304 - 03/04/18 11:04 PM Re: 8 3/4/stock axles/spool in a D100 - will it live long? [Re: grancuda]
humpty Offline
Loc: Minnesota, USA
I ran an 8 3/4 with stock axles and a spool with drag radials in the 11's for a couple years and at least 100 passes before swapping to a 35 spline spool and after market axles. The stock axles showed no signs of stress when I took them out. They are tough indeed.
72 Duster - 408ci W2, 10.18@131. Shooting for 10.0's in 2018!
https://m.youtube.com/watch?v=Q4P51j38-MI
#2461507 - 03/05/18 12:15 PM Re: 8 3/4/stock axles/spool in a D100 - will it live long? [Re: grancuda]
383man Offline
Loc: Balt. Md
I still have stock axles in my 63. I run 4.30's with a Detroit Locker and 30 x 9 radial slicks on the street. I have 7 years on them on the street with my 493 and about 20 track passes and last time I had the axles out they still looked fine. I plan to upgrade but so far they have held up better then I thought they would. Course my car is an auto car. Ron
My car...63 Sport Fury Max Wedge wanna be street car..with new 493 pump gas full exh eng.......10.76 @ 124.49 ! ! ! My page on the cool 62-65 Mopar site ! http://www.1962to1965mopar.ornocar.com/mmo82008.html
#2461544 - 03/05/18 01:31 PM Re: 8 3/4/stock axles/spool in a D100 - will it live long? [Re: grancuda]
ric3xrt Offline
Loc: Trumbauersville PA
Ran 4:30s in a 75 D100 440 4 speed , stock axles and spool for about 5 years(28k miles) , ran those old Mickey Thompson I tread tires on the street.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
#2461695 - 03/05/18 06:55 PM Re: 8 3/4/stock axles/spool in a D100 - will it live long? [Re: grancuda]
6pakdakota Offline
Loc: michigan
I daily drove a 360 Dakota for several years with a spool, 3.91 gears, and stock axles. No issues. The axles still looked perfect when the rear end came out of the truck.
25,496 Registered Members
193,164 Topics
Help me identify this 4.5 RB crank
by B1duster
09/25/18 11:38 PM
transmission fluid
by jonesboys
09/25/18 10:52 PM
What crank pulley do I neet?
by gsmopar
09/25/18 10:44 PM
When is the bigger U joint needed?
by radar
09/25/18 10:18 PM
