Oil leakage around rocker stands #2461196
03/04/18 10:46 PM
03/04/18 10:46 PM
Moparts
SSDart Offline OP
SSDart  Offline OP
Moparts
I was pre-lubing my engine on the engine stand today. We noticed a lot of oil leaking out past the rocker shaft hold down. Never really noticed this before. Has anyone seen this or rectified it before?
I did take one of the stock hold downs and put an O ring between the shaft and the hold down. Stopped the leak on the top but there was still a leak between the pedestal and the shaft....
Re: Oil leakage around rocker stands [Re: SSDart] #2461198
03/04/18 10:49 PM
03/04/18 10:49 PM
Maybe it is time to check the shafts for out of round at the mounting holes work scope twocents Good find up
There are fixes for all problems, determining the cause and fix is the hard part sometimes work
Which motor?
Let us know what you find thumbs
Re: Oil leakage around rocker stands [Re: SSDart] #2461199
03/04/18 10:57 PM
03/04/18 10:57 PM
Moparts
SSDart Offline OP
SSDart  Offline OP
Moparts
Shafts are round I mic'd them at assembly. Max. .001 out of round. The O ring fix's the top. Just wondering if there is something I can try under the shaft between pedestal and shaft?
Its a 340...
Re: Oil leakage around rocker stands [Re: SSDart] #2461212
03/04/18 11:29 PM
03/04/18 11:29 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
put a film of anerobic sealer on the pedestal. It won't come off & get in the oil.
Re: Oil leakage around rocker stands [Re: rickraw] #2461219
03/04/18 11:46 PM
03/04/18 11:46 PM
Moparts
SSDart Offline OP
SSDart  Offline OP
Moparts
Thanks Rick... Never heard of this sealer before. What is the consistency like? Does it get brittle like Loctite? Or is it closer to a silicone consistency?
Rick Have you ever tried using the Anaerobic sealer on the pedestals before?
Re: Oil leakage around rocker stands [Re: SSDart] #2461260
03/05/18 12:32 AM
03/05/18 12:32 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Use it sparingly. It gets hard when it cures and may need to be chipped off during disassembly. I've used it when I had tapered shims under the shafts.
