Re: Cold air inlet
[Re: firefighter3931]
#2464472
03/10/18 09:51 PM
03/10/18 09:51 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Hey Ron, here is the underside of my 1970 Road Runner cowl hood LOL
Re: Cold air inlet
#2464475
03/10/18 09:56 PM
03/10/18 09:56 PM
Posts: 43,096 Bend,OR USA
Cab_Burge
Is there any way to route the inlet tubes from the front of the radiator support down low on both sides to their air cleaner? If so that would supply some cool air pressure and very little debris into the tubes like might occur from the inlet mounted into the tire wells
Re: Cold air inlet
[Re: mkdart]
#2464708
03/11/18 01:21 PM
03/11/18 01:21 PM
Posts: 413 northeast ohio
mkdart
northeast ohio
old setup, duct work through fender to radiator core support next to headlight.
Re: Cold air inlet
[Re: StealthWedge67]
#2464878
03/11/18 07:38 PM
03/11/18 07:38 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
I use a ramairbox setup. Mine pulls through some holes I cut in the core support. I thought about the same location you are thinking of. I tried to fab the hoses off those locations, just couldn’t do it. To tight and odd angles to deal with. Perhaps you’re better than I at fabrication. I think it could be a decent place to pull from except in the rain. Let us know how it works out. Here’s mine: What degree separation is that? I’ve been thinking of this for my wagon.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
