small bolt pattern axles #2460599
03/03/18 08:13 PM
03/03/18 08:13 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Can small pattern axles. be changed to 4.5 pattern , or do I need different axles. on an 8/3/4 rear ??
Re: small bolt pattern axles [Re: dynamite] #2460613
03/03/18 09:17 PM
03/03/18 09:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It has been done, the new holes get pretty close to the outside of the flange so it's a good idea to use screw-in studs.
Re: small bolt pattern axles [Re: John_Kunkel] #2460658
03/03/18 11:33 PM
03/03/18 11:33 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I’ve run a screw-in stud conversion since 1994. About 70K miles
Re: small bolt pattern axles [Re: John_Kunkel] #2460672
03/04/18 12:18 AM
03/04/18 12:18 AM
iagree
I've had more than one set of A body 8 3/4 axles drilled and tapped for screw in studs to move and change the pattern to 5 on x 4.5 so we could use the stronger 1/2 inch studs and cheaper and easier to find wheels up
Re: small bolt pattern axles [Re: dynamite] #2460702
03/04/18 01:41 AM
03/04/18 01:41 AM
As said there ain't alot of meat to work with so go with the screw in studs. You would need lug centric wheels cuz the BBP wheel center hole will be bigger than the SBP axle register. You could fit a stiff fiberboard template with 5 ~7/16 holes and the center hole already cutout over the axle flange. make a pinprick for the center starting point in the template then 5 ~7/16" holes out on a 2" radius snug enough so the template will fit tightly over the current 7/16" studs then drill 5 new holes for the larger 1/2" studs. You want 5 pinprick marks equidistant around a 4.5" dia circle. figure where you want to locate the new holes correctly then make your first pinprick mark in the right spot then another 2.645" in a straight line tangent around the 4.5" circle then 3 more & the last one should be that same 2.645" distance then drill/tap the flange & drill the drum.
Re: small bolt pattern axles [Re: Cab_Burge] #2460704
03/04/18 01:48 AM
03/04/18 01:48 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
iagree
I just had this done on a set of stock A-Body axles (8-3/4) at a guys shop that specializes in building custom rear ends.
With machining the axles for the screw in studs, installing new green bearings and drilling the drums it cost me $300.
Re: small bolt pattern axles [Re: SNK-EYZ] #2460731
03/04/18 02:59 AM
03/04/18 02:59 AM
iagree
We use to pay $25.00 a axle plus the screw in 1/2 inch allen studs, my how I miss those days whiney We would drill our own drums also to keep cost down, I always made those new stud holes a little bit bigger and use the drum centering ring to locate the drums on the axles up
Re: small bolt pattern axles [Re: dynamite] #2460770
03/04/18 10:27 AM
03/04/18 10:27 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
If you are going to install green bearings, I'd get the new replacement aftermarket axles which are made just right for that to A Bodies Small bolt pattern conversion to big bolt pattern removing the thrust block. Doesn't make sense to keep the original ones converted.
A friend of mine BELIEVE IT OR NOT, cut the hub from B body axles donor, cut the hubs from his own A body axles and installed the ones removed from the B body ones. He made splines on axle to fit the B body hubs by pressure and also seam welded those. He ran at 1/4 mile races for long time with that on his 70 Swinger.
That's something tipically done down here when fixing heavy duty trucks axles.
Just an idea if you wanna try it. Can't tell the cost of that kind of job up the or even if you take care of doing that.
Re: small bolt pattern axles [Re: dynamite] #2460857
03/04/18 01:17 PM
03/04/18 01:17 PM
BDW Offline
BDW  Offline
How much are new axles? If your paying $300, I think I'd prefer something exact.
Re: small bolt pattern axles [Re: BDW] #2460921
03/04/18 03:06 PM
03/04/18 03:06 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Last set I had done, I took to the machine shop.
Machinist put them on a lathe, scribed a 4" circle, drilled and tapped 1/2"x20 every 72*.
This was back in the early '80s when new axles were about the same cost as they are now, $300. Lot of $$$ back then.
Best reason to buy aftermarket axles, you can have 10"x2" or larger brakes. With OEM 4" on 5 axles, your stuck with 10"x1.75" or smaller brakes.
Re: small bolt pattern axles [Re: B5 Bee] #2460965
03/04/18 04:33 PM
03/04/18 04:33 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Roughly $100 of the cost was the green bearings and installing them.
Since one of the original bearing felt rough when spinning the axles needed bearings.
Originally he was talking $150 to drill the axles to change the bolt pattern to 4.5 but he wanted to use Chevy studs because the use a smaller knurled diameter.
I wanted 1/2 inch studs, so that meant screw in studs to keep the diameter smaller.
I wanted the ability to go back to the original 4 inch bolt pattern in the future because at some point the car will be restored since it's a factory 383 car.
Re: small bolt pattern axles [Re: NachoRT74] #2461093
03/04/18 08:03 PM
03/04/18 08:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Fairly common back in the day, just bore the flange from both axles, press the SBP shaft into the BBP flange and weld at the outer end of the shaft. Henry's Axles, one of the first custom axle suppliers did it that way. As strong as the original when done properly.
Re: small bolt pattern axles [Re: dynamite] #2461114
03/04/18 08:39 PM
03/04/18 08:39 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Cool!
