Re: Hemi block casting dates
[Re: curbman68]
#2460429
03/03/18 12:39 PM
03/03/18 12:39 PM
Posts: 10,694 North Dakota
6PakBee
North Dakota
This is a list I've compiled over the years. Don't see any matches right off the bat.
8/16/1965 1/18/1966 6/14/1966 8/16/1966 8/28/1966 10/10/1966 9/30/1968 1/27/1970 3/18/1974
[Re: 6bblgt]
#2460803
03/04/18 12:04 PM
03/04/18 12:04 PM
robertop
is there a VIN pad stamping area & a "MN" or any other stampings on the bottom?
I can add these "*":
8/16/1965 1/18/1966 6/14/1966 8/16/1966 8/28/1966 10/10/1966 * 1/15/1968 9/30/1968 * 11/18/1968 * 5/10/1969 * 5/26/1969 1/27/1970 3/18/1974 Add the date 4/15/68, the first of them was installed on the first Hemi roadrunner, built on 7/28, Lynch road plant.
[Re: 6bblgt]
#2460991
03/04/18 05:33 PM
03/04/18 05:33 PM
Posts: 21,495 N.E. OHIO, USA
A12
N.E. OHIO, USA
the closest cast 1/15/68 to assembled 3/12/68 dates I have any info on are ~2-months, but most are much longer - that may be due to size of batches & rate at which they were used was it intentional?? the '66 & 1/68 blocks don't have the raised pad for the VIN stamp I think I remember actually seeing a photo of raw just cast Hemi blocks rusting and stacked outside what may have been the casting foundry?? Seems to make some sense to have the cast iron age at least a short time.
[Re: hemi71x]
#2461150
03/04/18 09:36 PM
03/04/18 09:36 PM
Posts: 1,672 Virginia
HemiStan
Virginia
I have got this block that is cast 1-26-70.
Stan
[Re: 6bblgt]
#2461182
03/04/18 10:16 PM
03/04/18 10:16 PM
Posts: 1,320 VA
dragon slayer
VA
the closest cast 1/15/68 to assembled 3/12/68 dates I have any info on are ~2-months, but most are much longer - that may be due to size of batches & rate at which they were used was it intentional?? the '66 & 1/68 blocks don't have the raised pad for the VIN stamp I will check again, but I have a 1/15/68 block assembled 24May68 and it has the raised pad for a VIN but it is blank. Vin is in the normal spot for a 68 hemi motor.
