727 Trans #2460425
03/03/18 12:33 PM
03/03/18 12:33 PM
usa,pa
jkwedge540 Offline OP
usa,pa
Does anyone make a input shaft for a 727 to run a Turbo 400 toque converter. I read something on it a while back, but can’t remember where.
Re: 727 Trans [Re: jkwedge540] #2460515
03/03/18 03:32 PM
03/03/18 03:32 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
The converter builder can use whatever core and put whatever you need in it. The problem is the GM cores are physically thicker than a 727 core. You will have to space the trans back from the motor 3/4" to fit a GM core.
Re: 727 Trans [Re: jkwedge540] #2460727
03/04/18 02:56 AM
03/04/18 02:56 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Call Protrans. They do quite a few different shaft configurations iirc.
Re: 727 Trans [Re: jkwedge540] #2460734
03/04/18 03:09 AM
03/04/18 03:09 AM
Why do you want to do this confused work shruggy
Re: 727 Trans [Re: Cab_Burge] #2460806
03/04/18 12:09 PM
03/04/18 12:09 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
There is a much larger selection of GM cores.
Re: 727 Trans [Re: Cab_Burge] #2461366
03/05/18 09:42 AM
03/05/18 09:42 AM
usa,pa
usa,pa
Hard to get a good toque converter to hold a lot of power with a 727. A lot of companies can’t or won’t do it .
Re: 727 Trans [Re: Cab_Burge] #2461368
03/05/18 09:50 AM
03/05/18 09:50 AM
st.louis,mo.
dart games Online content
dart games  Online Content
st.louis,mo.
727s are junk
Re: 727 Trans [Re: jkwedge540] #2461527
03/05/18 03:51 PM
03/05/18 03:51 PM
A727Tflite Offline
A727Tflite  Offline
Jkwedge540 - what engine power/torque are in your plans ?
Re: 727 Trans [Re: dart games] #2461529
03/05/18 04:04 PM
03/05/18 04:04 PM
Minn
SportF Offline
SportF  Offline
Minn
727s are junk
Everybody is entitled to an opinion for sure. Have you personally had a 350 or 400 apart? I don't care for that design. That and my 727's have treated me well.
But, I probably am not making the power you are.
If I didn't like the mopar reputation and body styles so much, I'd be racing a whole Chevy, not just the trans.
Re: 727 Trans [Re: jkwedge540] #2461556
03/05/18 05:02 PM
03/05/18 05:02 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
very few quality converters are made now with OEM cores, most are using billet covers. At least the last couple I purchased were.
As mentioned 727's have a small dimension for the converter. My old model J converter used a ford cortina core for example.
Re: 727 Trans [Re: jkwedge540] #2461599
03/05/18 06:15 PM
03/05/18 06:15 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've had no real issues running close to 900 mine with stock input/ouput. The stock front planet carrier is a maintenance item. With a brake we run the steel part. Aprox 850 running a brake with stock shafts and rear planetarys.
Doug
Re: 727 Trans [Re: dvw] #2461659
03/05/18 08:54 PM
03/05/18 08:54 PM
usa,pa
usa,pa
I have and A&A with all the bells and whistles. Every converter company I talk to says they can not help me. Car is heavy with a lot of spray. I just want to try and use a 400 toque converter with the 727. Never really had and issue with the trans.
Re: 727 Trans [Re: jkwedge540] #2461671
03/05/18 09:14 PM
03/05/18 09:14 PM
Texas
RustyM Offline
RustyM  Offline
Texas
have you talked to FTI down in florida?
Re: 727 Trans [Re: jkwedge540] #2461678
03/05/18 09:25 PM
03/05/18 09:25 PM
up Thanks for answering, none of my own race motors make above 845 HP so I haven't had to deal with a converter made for above that HP yet.
My current bracket car had a Mikes Ultraglide with a 9 inch converter made for a blown B1 motor ran on Methanol in it when I bought it so I used it, it has worked well up
I may switch to a A-1 8 inch converter I have(per Al and Adams urging) as the current bracket motor barely cracks the 700 + HP numbers on a DTS engine dyno at 4300 ft. on E85 shruggy The first 1.27 60 ft. in that car without using the throttle stop reminded me to not sit up and lean forward when letting go of the trans brake realcrazy whiney
I do have a new car under construction that I was planning on using a older Pro Trans SS/AH 727 that I have with all the bell and whistles that came in them a long time ago, maybe it's time to call Dave and ask him if that is viable still or not now confused work Maybe it is time for a new state of the art Proflyte with converter made for the new car, hopefully the new 555 C.I. B1-MC motor will make north of 1000 HP on either E85 or straight Methanol luck
Re: 727 Trans [Re: jkwedge540] #2461731
03/05/18 10:46 PM
03/05/18 10:46 PM
Minn
SportF Offline
SportF  Offline
Minn
Did you talk to M&M transmission in Missouri? http://mandmtransmission.com
Re: 727 Trans [Re: jkwedge540] #2461751
03/05/18 11:33 PM
03/05/18 11:33 PM
Penna
70satelliteguy Offline
Penna
"Hard to get a good toque converter to hold a lot of power with a 727. A lot of companies can’t or won’t do it ."
"727s are junk "
Mt PTC converter has lasted 8 years without any problems. My 727 has a lot of A&A goodies and serviced regularly but I hardly consider it junk.
3560 lbs. 572 wedge,transbrake etc. . 900+hp + 300 Nitrous. Race weekly during the summer on motor and 4-5 heads up races on Nitrous.
Mike
