69 440 (A/C) coolant leak?
#2460236
03/02/18 11:42 PM
03/02/18 11:42 PM
Posts: 1,177 People's Republic of Kali
70runner
Have a coolant leak, 69 Charger 440 with A/C, dripping from idler bracket lower bolt area. Does anyone know if either of the 2 idler bracket bolts enters a water jacket?
Re: 69 440 (A/C) coolant leak?
[Re: 70runner]
#2460390
03/03/18 10:46 AM
03/03/18 10:46 AM
Posts: 6,387 Abilene, Texas
fastmark
Abilene, Texas
I fought my newly rebuilt 70 Charger 440 with a water leak dripping from the lower rad hose. Ended up being the thermostat housing leaking behind the AC compressor. Had to remove it to find the leak. They can leak from anyplace.
[Re: 70runner]
#2460482
03/03/18 02:06 PM
03/03/18 02:06 PM
RapidRobert
for diagnosing you can get a tank valve from O'reillys for less than $3 & screw it into the 1/8 NPT cooling temp sender port & pump it up to 10 lbs with shop air. some dish soap in a squirt bottle will help show bubbles.
[Re: mgoblue9798]
#2460709
03/04/18 01:54 AM
03/04/18 01:54 AM
RapidRobert
Bro I've been on here 13 yrs & I learn something new here EVERY day. there are many many off the charts extremely sharp/knowledgeable guys on here.
[Re: RapidRobert]
#2461153
03/04/18 09:37 PM
03/04/18 09:37 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Yep, works great. I got the idea from Robert as well. Smart fella. Be careful using the air though. Radiator only holds up to about 16# in good shape. Don't need near that for leak to show itself. I used a hand held bicycle pump.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#2461244
03/05/18 12:16 AM
03/05/18 12:16 AM
RapidRobert
^^^ agreed, get several PSI in there/turn off the stereo/listen closely & you'll likely hear it
