69 440 (A/C) coolant leak? #2460236
03/02/18 11:42 PM
03/02/18 11:42 PM
People's Republic of Kali
70runner Offline OP
70runner  Offline OP
Have a coolant leak, 69 Charger 440 with A/C, dripping from idler bracket lower bolt area. Does anyone know if either of the 2 idler bracket bolts enters a water jacket?
Re: 69 440 (A/C) coolant leak? [Re: 70runner] #2460254
03/03/18 12:26 AM
03/03/18 12:26 AM
santa anna, Tx.
charles6970 Offline
charles6970  Offline
santa anna, Tx.
Yes.
obviously.
Re: 69 440 (A/C) coolant leak? [Re: 70runner] #2460355
03/03/18 05:37 AM
03/03/18 05:37 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
No they don't enter a water jacket. They are one inch deep and stop. But they do go through the water pump housing and attach it to the block. Could be heater hoses.
Here are pictures of an AC car with the idler removed and installed.
I'm working on a 1957 392 and I cannot believe how many bolt holes go into the water jackets. Crazy really.
Re: 69 440 (A/C) coolant leak? [Re: 70runner] #2460390
03/03/18 10:46 AM
03/03/18 10:46 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I fought my newly rebuilt 70 Charger 440 with a water leak dripping from the lower rad hose. Ended up being the thermostat housing leaking behind the AC compressor. Had to remove it to find the leak. They can leak from anyplace.
Re: 69 440 (A/C) coolant leak? [Re: 70runner] #2460482
03/03/18 02:06 PM
03/03/18 02:06 PM
for diagnosing you can get a tank valve from O'reillys for less than $3 & screw it into the 1/8 NPT cooling temp sender port & pump it up to 10 lbs with shop air. some dish soap in a squirt bottle will help show bubbles.
Re: 69 440 (A/C) coolant leak? [Re: 70runner] #2460491
03/03/18 02:30 PM
03/03/18 02:30 PM
70runner Offline OP
70runner  Offline OP
Thx all, appreciate replies. The air pressure test with temp sender port is great idea.
Re: 69 440 (A/C) coolant leak? [Re: RapidRobert] #2460492
03/03/18 02:31 PM
03/03/18 02:31 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Now that is a slick idea and I am kicking myself for not thinking about it before.
Re: 69 440 (A/C) coolant leak? [Re: mgoblue9798] #2460709
03/04/18 01:54 AM
03/04/18 01:54 AM
Bro I've been on here 13 yrs & I learn something new here EVERY day. there are many many off the charts extremely sharp/knowledgeable guys on here.
Re: 69 440 (A/C) coolant leak? [Re: RapidRobert] #2461153
03/04/18 09:37 PM
03/04/18 09:37 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Yep, works great.
I got the idea from Robert as well.
Smart fella. up
Be careful using the air though.
Radiator only holds up to about 16# in good shape.
Don't need near that for leak to show itself.
I used a hand held bicycle pump.
I have mechanical Aptitude.
I can screw up anything.
Re: 69 440 (A/C) coolant leak? [Re: bboogieart] #2461244
03/05/18 12:16 AM
03/05/18 12:16 AM
^^^ agreed, get several PSI in there/turn off the stereo/listen closely & you'll likely hear it
