woho it runs #245997
03/07/09 05:22 PM
03/07/09 05:22 PM
Kissimmee Fl.
dusturbd340W5 Offline OP
Kissimmee Fl.
fired the car up today motor runs and sounds great took it for a quick run down the street every thing seems good trans brake worked delay box worked brakes worked.
Only 2 small problems I have 3 freeze plugs leaking for some reason and I have a little to much oil pressure.
It is carrying 70lbs at an idle in neutral and if I tach it up it pegs the gauge at over 100lbs Damn.
I shot video but it is on an old camcorder that is 8mm tape so I have no way to post it right now.
But all in all things went good I need to back the timing on the crank trigger down its a little high at 43 deg.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: woho it runs [Re: dusturbd340W5] #245998
03/07/09 05:25 PM
03/07/09 05:25 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: woho it runs [Re: WILD BILL] #245999
03/07/09 05:30 PM
03/07/09 05:30 PM
Kissimmee Fl.
Kissimmee Fl.
Yes thats how I feel wish the oil pressure wasnt so high
Re: woho it runs [Re: dusturbd340W5] #246000
03/07/09 05:42 PM
03/07/09 05:42 PM
Q
Quicktree Offline
Quicktree  Offline
Q
way to go may try aq different guage. what kind of pump did you use? mine idles at 60 and goes up another 10-20
Re: woho it runs [Re: Quicktree] #246001
03/07/09 05:47 PM
03/07/09 05:47 PM
Kissimmee Fl.
Kissimmee Fl.
gauge is a new Autometer Sport Comp the pump is a Melling HV that I ported and cleaned all the flashing out of and polished up and the gauge reads off the oil filter housing.
Also keep in mind this block has lifter bushings also restricted oil to cam bearings trying to keep all the oil on the crank as we could.
Re: woho it runs [Re: dusturbd340W5] #246002
03/07/09 09:54 PM
03/07/09 09:54 PM
Kissimmee Fl.
Kissimmee Fl.
any ideas on the oil pressure should I just cut a little off the srping in the pump if so how much.
Re: woho it runs [Re: dusturbd340W5] #246003
03/07/09 10:07 PM
03/07/09 10:07 PM
Q
Quicktree Offline
Quicktree  Offline
Q
no burnouts yet? if it doesn
t blow the filter off I would woryy about it
Re: woho it runs [Re: Quicktree] #246004
03/07/09 10:46 PM
03/07/09 10:46 PM
Kissimmee Fl.
Kissimmee Fl.
no burn outs yet may try and fix the freeze plugs tomorrow.
Re: woho it runs [Re: dusturbd340W5] #246005
03/07/09 11:04 PM
03/07/09 11:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Pour in a can of Bars leak and take out the 50 weight oil
Glad to hear she fired up... also try the timing about 34*
Re: woho it runs [Re: MR_P_BODY] #246006
03/07/09 11:40 PM
03/07/09 11:40 PM
Kissimmee Fl.
Kissimmee Fl.
I considered the stop leak and I am running 15/40 Rotella.
Re: woho it runs [Re: dusturbd340W5] #246007
03/07/09 11:44 PM
03/07/09 11:44 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
lets see the ride
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: woho it runs [Re: 10 o to go] #246008
03/07/09 11:45 PM
03/07/09 11:45 PM
Kissimmee Fl.
Kissimmee Fl.
here ya go
Re: woho it runs [Re: dusturbd340W5] #246009
03/07/09 11:45 PM
03/07/09 11:45 PM
Kissimmee Fl.
Kissimmee Fl.
motor
Re: woho it runs [Re: dusturbd340W5] #246010
03/08/09 12:14 AM
03/08/09 12:14 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Buy this and set your pressure right takes 2 minutes to install
http://chucker54.stores.yahoo.net/milbrbadregk.html
Re: woho it runs [Re: Dodgem] #246011
03/08/09 12:15 AM
03/08/09 12:15 AM
Kissimmee Fl.
Kissimmee Fl.
that says for a big block I am running a small block
Re: woho it runs [Re: dusturbd340W5] #246012
03/08/09 02:05 AM
03/08/09 02:05 AM
florida,usa
rdakota340 Offline
rdakota340  Offline
florida,usa
It's about time when we taken it to track OSW TNT on wednesdays just put some lighter oils in her you will be fine, let me know I want go up that way and take my truck.
Turbos The Only Power Adder!
Re: woho it runs [Re: dusturbd340W5] #246013
03/08/09 09:26 AM
03/08/09 09:26 AM
Orlando Florida
blown572dart Offline
Orlando Florida
sweeeeeeeeeet
Re: woho it runs [Re: dusturbd340W5] #246014
03/08/09 09:51 AM
03/08/09 09:51 AM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
Cool, happy for you Woody. it's been a long time coming to this point. Let me and Kenny know when you head out to Lakeland
DC
