Rear shock help #2459993
03/02/18 05:05 PM
03/02/18 05:05 PM
Midland,Tx
wyldebill Offline OP
Midland,Tx
I'm in the building phase of my 68 valiant, and I'm looking at rear shocks. How much travel do I need on a leaf spring car?
Re: Rear shock help [Re: wyldebill] #2460022
03/02/18 06:19 PM
03/02/18 06:19 PM
AndyF Offline
AndyF  Offline
Depends on the springs used. Super Stock springs have a lot of travel so you might need 8 or 10 inches of travel. That is why those cars used to use Imperial stocks back in the day and then guys switched to pickup shocks or Rancho shocks. We would set them up with 2 inches of compression and 6 to 8 inches of drop since those cars would really stand up and go.
If you have Calvert split mono leaf springs then you only need about 6 inches of travel. 2 inches of compression and 4 inches of drop should do it. Or perhaps 1.5 inches of compression and 4.5 of drop if the track is smooth.
Re: Rear shock help [Re: wyldebill] #2460042
03/02/18 07:05 PM
03/02/18 07:05 PM
Midland,Tx
Midland,Tx
Thanks, I have a set of Calvert mono's.
Re: Rear shock help [Re: wyldebill] #2460043
03/02/18 07:05 PM
03/02/18 07:05 PM
Midland,Tx
Midland,Tx
Re: Rear shock help [Re: wyldebill] #2460206
03/02/18 10:34 PM
03/02/18 10:34 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
Andy's got it right. I ended up with a 9" shock (AFCO 3890 specifically) on my 72 with Calvert split monos stock ride height bends. That left me with nearly 2" of compression at race weight and 2" of extension remaining without the shocks connected and the rear hanging off the ground.
I would take some mesurments before ordering your shocks to be sure.
Re: Rear shock help [Re: wyldebill] #2460485
03/03/18 02:13 PM
03/03/18 02:13 PM
AndyF Offline
AndyF  Offline
I had to make my own shock plates so I could get the lower mount in the correct location. For example, if you want 2 inches of compression and the rest for extension the lower mount needs to be located in the right spot. I couldn't find shock plates that did the trick so I welded up my own.
Re: Rear shock help [Re: wyldebill] #2460595
03/03/18 07:58 PM
03/03/18 07:58 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
what are you looking to do with the car how fast and what tire will this be a power adder
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Rear shock help [Re: WHITEDART] #2460976
03/04/18 05:15 PM
03/04/18 05:15 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
No reply kinda sets off a RED flag to me.........and no Pics work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Rear shock help [Re: AndyF] #2461482
03/05/18 02:35 PM
03/05/18 02:35 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Nice work Andy.
Don
