Re: Rear shock help
[Re: wyldebill]
#2460485
03/03/18 02:13 PM
03/03/18 02:13 PM
Posts: 30,992 Oregon
AndyF
I had to make my own shock plates so I could get the lower mount in the correct location. For example, if you want 2 inches of compression and the rest for extension the lower mount needs to be located in the right spot. I couldn't find shock plates that did the trick so I welded up my own.
Re: Rear shock help
[Re: wyldebill]
#2460595
03/03/18 07:58 PM
03/03/18 07:58 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I'm in the building phase of my 68 valiant, and I'm looking at rear shocks. How much travel do I need on a leaf spring car? what are you looking to do with the car how fast and what tire will this be a power adder
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Rear shock help
[Re: WHITEDART]
#2460976
03/04/18 05:15 PM
03/04/18 05:15 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I'm in the building phase of my 68 valiant, and I'm looking at rear shocks. How much travel do I need on a leaf spring car? what are you looking to do with the car how fast and what tire will this be a power adder No reply kinda sets off a RED flag to me.........and no Pics
Re: Rear shock help
[Re: AndyF]
#2461482
03/05/18 02:35 PM
03/05/18 02:35 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
I had to make my own shock plates so I could get the lower mount in the correct location. For example, if you want 2 inches of compression and the rest for extension the lower mount needs to be located in the right spot. I couldn't find shock plates that did the trick so I welded up my own. Nice work Andy. Don
