#2459874 - 03/02/18 09:48 AM 72-80 Dash inserts?
Mr onetwo Offline
Loc: Coastal Maine
Is anyone making metal inserts for these dashes.I searched and can't find anything current.Was thinking turned stainless with new Speedhut gauges would be nice.
Edited by Mr onetwo (03/02/18 10:09 AM)
#2460019 - 03/02/18 03:12 PM Re: 72-80 Dash inserts? [Re: Mr onetwo]
bboogieart Offline
Loc: Lost and Spaced
I like this idea.
Really like that gauge. up
Thought about doing this myself.
There is a water jet shop up the road from me, but I figure it would cost more than my trucks are worth.
Wouldn't hurt to go ask em. shruggy
My plan was to get a scrap piece of 1/4" plywood or plastic and make the pattern.
If it comes out good, then I'd try the turned aluminum.
Pretty sure the hardware store or tractor supply would carry it.
I couldn't justify the cost of stainless on my old trucks.
I have mechanical Aptitude.
I can screw up anything.
#2460269 - 03/02/18 09:46 PM Re: 72-80 Dash inserts? [Re: Mr onetwo]
poorboy Offline
Loc: Freeport IL USA
I saw turned metal backing panels on sale someplace, maybe Speedway?
I have a big hole where the instrument cluster once set, so I have to put something there to mount my gauges to. I was originally thinking I would just use sheet metal and paint the whole dash body color, or the dash body color and the mounting plate black or something. My gauges are 3 3/8" in diameter, I have the speedo and the other is 4 gauges in one set. My gauges have a black face with a black trim ring. The numbers are white and the pointer is red.
I do have a piece of 18 gauge brushed stainless steel (think fridge front) here I could use to mount my new gauges, but once the holes are cut, any clean up removes the "brushed" look. I suppose I could cut the holes undersized and use a rotating cutter to bring the holes out to size.
I also have a piece of 5/16" thick aluminum left from a job I did, I could make the gauge backing from that as well. Gene
#2460301 - 03/02/18 10:46 PM Re: 72-80 Dash inserts? [Re: Mr onetwo]
moparborn Offline
Loc: Pa. U.S.A.
You can buy vinyl wrap in engine turned finish and lay it on your existing panel.
#2460332 - 03/02/18 11:41 PM Re: 72-80 Dash inserts? [Re: Mr onetwo]
70Duster440 Offline
Loc: Washington State
We fabbed a 3 piece aluminum insert over a heavily modified (ie: hacked up) donor bezel that served as a foundation so it would all go back in as one piece using the same anchor points. A pair of Speedhut combination gauges monitor vitals but with the radio delete there’s a lot of available real estate. The combo gauges are looking lonely.
#2461361 - 03/05/18 06:27 AM Re: 72-80 Dash inserts? [Re: Mr onetwo]
Mr onetwo Offline
Loc: Coastal Maine
I have talked to these guys...FPM Metals, but I may try the wrap idea and adapt new gauges to the existing bezel.
Edited by Mr onetwo (03/05/18 06:28 AM)
#2464260 - 03/10/18 10:11 AM Re: 72-80 Dash inserts? [Re: Mr onetwo]
LilRed7879 Offline
Loc: Orange Park FL.
David S. Part Time Owner Dodge Connection www.dodgeconnection.com 904-688-0911
#2465090 - 03/12/18 06:41 AM Re: 72-80 Dash inserts? [Re: LilRed7879]
Mr onetwo Offline
Loc: Coastal Maine
Very nice work...thanks for the link!
#2465876 - 03/13/18 03:04 PM Re: 72-80 Dash inserts? [Re: Mr onetwo]
bboogieart Offline
That is very nice. up
Gives me hope.
I don't have a mill, but I'm gonna give it a try.
25,490 Registered Members
193,068 Topics
'76 New Yorker on Feebay
by larrymopar360
38 minutes 56 seconds ago
Exhuast Manifold Gaskets
by GTXKARL
44 minutes 0 seconds ago
Person decapitated at Nola raceway
by 340SIX
59 minutes 8 seconds ago
small or big block lakewood bellhousing and wiw
by TB3CUDA
Today at 02:20 PM
