#2459118 - 02/28/18 08:00 PM Need part # for fuel filler neck grommet '79 Power Wagon
larrymopar360 Offline
Loc: Central Florida
My rear of driver's seat tank needs a new fuel fill neck grommet. It's leaking fumes stinking up the cab.
I could really use the part number to help me locate a new one.
Thanks!
Larry
Facts are stubborn things.
#2459286 - 03/01/18 05:55 AM Re: Need part # for fuel filler neck grommet '79 Power Wagon [Re: larrymopar360]
ruderunner Offline
Loc: ohio
Iirc same as 68-69 b body. I think the outside one is the same as well.
Doorman makes them.
#2459433 - 03/01/18 12:42 PM Re: Need part # for fuel filler neck grommet '79 Power Wagon [Re: ruderunner]
Doorman makes them.
I figured it's the same one as on some other vehicles, but just can't find one that comes up a match. Tried rockauto.
#2460370 - 03/03/18 06:42 AM Re: Need part # for fuel filler neck grommet '79 Power Wagon [Re: larrymopar360]
ruderunner Offline
Loc: ohio
Are you looking for a new one to seal or one that looks correct as well?
I grabbed a couple Dorman ones for my crew cab, haven't installed them yet as truck needs paint big time.
I'll try to get the pn later today.
#2460506 - 03/03/18 12:11 PM Re: Need part # for fuel filler neck grommet '79 Power Wagon [Re: ruderunner]
I just want one that properly fits and seals tank so I don't smell fumes. 1979 standard cab behind seat tank.
Thank you.
Larry
#2460659 - 03/03/18 08:37 PM Re: Need part # for fuel filler neck grommet '79 Power Wagon [Re: larrymopar360]
BIGGERED Offline
Reasonable Title
Loc: North East USA
Larry
4002010 GROMMET Filler to Body
2221771 GROMMET Filler to Tank
Strangely enough Brad's NOS may not be the most expensive option.
Red
#2460909 - 03/04/18 11:55 AM Re: Need part # for fuel filler neck grommet '79 Power Wagon [Re: BIGGERED]
Originally Posted By BIGGERED
Larry
Red
Thank you very much!!!
Brad's not most expensive??! Don't be silly! grin
Thanks again!
#2460913 - 03/04/18 12:00 PM Re: Need part # for fuel filler neck grommet '79 Power Wagon [Re: larrymopar360]
I'm looking at the 4002010 and wondering if; while I love NOS, in this case I should buy aftermarket? Do you think NOS might be too old and dried out/cracked? I see Dorman makes them.
Thanks again for numbers Red.
#2460939 - 03/04/18 12:47 PM Re: Need part # for fuel filler neck grommet '79 Power Wagon [Re: larrymopar360]
135sohc Offline
Loc: SoMd, USA
4002010 can be had new from the dealership or countless listings on ebay.
#2461010 - 03/04/18 03:06 PM Re: Need part # for fuel filler neck grommet '79 Power Wagon [Re: 135sohc]
Once I got the part number, I saw them on ebay but figured they were NOS and was concerned about dry rot. But if they are still in production then I will get a new one. Just bought a new Mopar one off ebay for $17.00 including shipping.
Edited by larrymopar360 (03/04/18 03:15 PM)
#2464469 - 03/10/18 06:43 PM Re: Need part # for fuel filler neck grommet '79 Power Wagon [Re: larrymopar360]
Btw, I think the numbers are reversed as to where they go (I believe the 2221771 is filler to body), but thanks again, I got them both and am very grateful to you for providing part numbers!!
#2464495 - 03/10/18 08:05 PM Re: Need part # for fuel filler neck grommet '79 Power Wagon [Re: larrymopar360]
BIGGERED Offline
Reasonable Title
Loc: North East USA
Glad they are going to work out.
My apologies for errors in the parts manual.
The pictures are correct but descriptions are not. I unfortunately did not look at the pics.
Red
#2464705 - 03/11/18 11:19 AM Re: Need part # for fuel filler neck grommet '79 Power Wagon [Re: BIGGERED]
Red
No problem thanks again!
25,622 Registered Members
195,479 Topics
76 d100 gas tank filler neck replacement
by 76_d100
14 minutes 50 seconds ago
Trick Flow 240 Heads
by RROD
24 minutes 39 seconds ago
Looking for In order of preference ignition system
by modelmakerinc
Today at 08:25 PM
"Moron pattern detected"
by A990
Today at 07:33 PM
