2" TTI vs other headers ground clearance #2458936
02/28/18 04:10 PM
02/28/18 04:10 PM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
Hey everyone, been a long time since I posted.
On my dart, I currently have 2" TTIs (vintage 12 or so years ago when I bought them) on a low deck. I'm not thrilled with the ground clearance, they hang down, and don't look all the nice.
You can ask why I have these headers on the engine I am currently am running, and I totally agree, they are overkill. At the time, I didn't want to buy parts twice, and was planning a stroker build (and still am..... someday....).
Anyway, I'm trying to determine for any of you that have went from 2" TTIs to possibly the 1 7/8" TTIs on a low deck, how much the ground clearance improved? The 2" I know were designed for the RB, but I'm not actually sure how different they are as I've never seen them side by side.
Otherwise, thinking about a set of Shumacher's or maybe something different. The Dart has AlterKtion, so I don't have as many clearance issues to deal with.
Thanks!
383, Hemi 4-Speed, AlterKtion, D60
Re: 2" TTI vs other headers ground clearance [Re: Crazy68Dart] #2459116
02/28/18 10:54 PM
02/28/18 10:54 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Do you have RB headers on a low deck engine?
Re: 2" TTI vs other headers ground clearance [Re: Crazy68Dart] #2459148
02/28/18 11:41 PM
02/28/18 11:41 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
There was a set of Doug's D451's on the return table at Summit the other day for $300 with 25% off that. Some guys have used 1 7/8" B-body tubes on A-bodies with small dings shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: 2" TTI vs other headers ground clearance [Re: fourgearsavoy] #2459207
03/01/18 01:13 AM
03/01/18 01:13 AM
Canton, Ohio
Canton, Ohio
Bobby, if the two inch ttis are considered RB headers then yes, I am. That is part of what I want to confirm. They hang low.
Gus, thanks. I'm not familiar with those headers, they low deck specific? I'll look them up. Maybe I'll run up to summit over lunch tomorrow. They are probably gone but who knows.
Re: 2" TTI vs other headers ground clearance [Re: Crazy68Dart] #2459338
03/01/18 12:19 PM
03/01/18 12:19 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
On the TTI site they say a low deck engine must use a raised exhaust port head to run the 2" headers.
Re: 2" TTI vs other headers ground clearance [Re: bobby66] #2459348
03/01/18 12:33 PM
03/01/18 12:33 PM
Canton, Ohio
Canton, Ohio
Yeah, I saw that note too. I *think* that was mainly for clearance issues around the block, etc. I had to grind my block and slightly ding the header on the pass side. Otherwise, no issues, other than they hang lower than I want.
How much higher are raised exhaust port heads than standard? I'm sure it would help some with overall ground clearance, but I wonder how much...
Re: 2" TTI vs other headers ground clearance [Re: Crazy68Dart] #2459401
03/01/18 02:33 PM
03/01/18 02:33 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I have a 440-based Duster, Indy heads, with those headers. No problem with ground clearance; Milodon pan is lower than headers. Car sits stock height if not a bit lower. They do interfere at pitman arm.
Re: 2" TTI vs other headers ground clearance [Re: Crazy68Dart] #2459413
03/01/18 02:43 PM
03/01/18 02:43 PM
Ohio
W
wedgg440 Offline
wedgg440  Offline
W
Ohio
If you go to the TTI catalog you will learn that when using a low deck block in an A-body you will need to use Indy SR heads on your build.The Indy SR heads have 3/4"raised exhaust ports and will raise your headers that amount.I built a 1970 Duster with that setup about 5 years ago and it fit perfectly with good ground clearance.
Re: 2" TTI vs other headers ground clearance [Re: wedgg440] #2459434
03/01/18 03:44 PM
03/01/18 03:44 PM
Canton, Ohio
Canton, Ohio
3/4" of an inch up would still not make me happy.
I'll try to get a pic of the headers and how low they are hanging and post. They are definately lower than the oil pan (rear sump 6 quart Mopar pan to clear rack on AlterKtion).
Re: 2" TTI vs other headers ground clearance [Re: Crazy68Dart] #2459442
03/01/18 03:55 PM
03/01/18 03:55 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I've run their 1-3/4" headers on 400 and 440 engines and had plenty of ground clearance. Easy to work around, too.
Re: 2" TTI vs other headers ground clearance [Re: fourgearsavoy] #2459782
03/02/18 04:39 AM
03/02/18 04:39 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Gus beer
I wish Doug's made something bigger than 1 3/4".
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 2" TTI vs other headers ground clearance [Re: OhioMopar] #2461217
03/04/18 11:42 PM
03/04/18 11:42 PM
Canton, Ohio
Canton, Ohio
Gus beer
D452... I think that is a 2" header.
Here is a not so great pic of the headers on my car.
Re: 2" TTI vs other headers ground clearance [Re: Crazy68Dart] #2461393
03/05/18 11:25 AM
03/05/18 11:25 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Gus beer
Oops. I guess I didn't finish my thought. Bigger than 1 3/4 for a low deck.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 2" TTI vs other headers ground clearance [Re: OhioMopar] #2461467
03/05/18 01:53 PM
03/05/18 01:53 PM
Canton, Ohio
Canton, Ohio
Gus beer
No prob! I should have put that together myself, haha.
Re: 2" TTI vs other headers ground clearance [Re: Crazy68Dart] #2461536
03/05/18 04:19 PM
03/05/18 04:19 PM
Chicago
PurpleBeeper Offline
Chicago
I've never run TTI's at all, but I have run 2" Hookers & 2" Heddmans. The Hookers gave me about 2" more ground clearance vs. Heddman. Hookers had 1 slip tube & all 4 Heddman primaries were slip tubes. Hope this helps at least a little.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
