Page 2 of 2 < 1 2
#2451057 - 02/12/18 10:33 PM Re: A Body - Cars For Sale - 1st Quarter [Re: moparts]
E-Ticket Offline
Loc: Louisville, KY
Fairly clean body except the lower rear section of the quarter panels have some light rust but overall a solid body. Tail light panel needs straightening. Floor pans, trunk pan, engine compartment are all pretty nice as are the frame rails. Rear inner wheel wells have been cut and removed.
No motor or transmission, no interior to speak of other than what you see in the pictures. Has small bolt pattern front disc brakes (missing calipers), 7-1/4 rear end. All that comes with the car are in the pictures shown. The back seat (bottom) is not shown but is included. Car has a Georgia title.
Located in Louisville, KY!
Please PM me if interested!
Thanks for the ad space Moparts!!!
"Fat drunk and stupid is no way to go through life son......"
#2455834 - 02/22/18 06:47 PM Re: A Body - Cars For Sale - 1st Quarter [Re: moparts]
Dragula Offline
Loc: Taxes R-US, NY
I have two 9 second pump gas cars, and do not need both, so I putting my pump gas Duster up for sale.
Its a 72ish Duster with a lot of good parts on it, that is very easy to work on. I have owned it five years and raced it for six years. Every year the engine gets freshened and all new bearings and rings with a thorough inspection and anything else it needs replaced. This past winter, it had all the rings and bearings replaced as well as the timing chain and all the gaskets.
The car is a back half big tire four link coil over car with an S&W rear sway bar. Rear tires are 17x33 slicks and a narrowed Dana 60 with 4.56 gears. The dana has a bearing preload style cover on it as well. Tires have a full season on them, and still have tread.
Car has a full cage, and is currently certed to 8.50. It has a full halo, and front bars, knee bar and window net, one seat and the typical 5-way harness an aluminum dash with the typical gauges in it. Interior also has aluminum door panels and sail panels and the window cranks were left intact and are very functional.
Trunk area has the typical back half treatment with aluminum tubs and trunk floor with fuel cell. 275 Magna fuel pump is mounted underneath. 1/2 line up to the carb and -10 to the pump and return line.
Front of the chassis is Magnum force with DA coil overs and no inner fenders. The shock towers are tied right into the front bars and everything is super easy to work on.
Body is in fair to good condition. Paint is six years old, and is about a five footer. Has a dent where the hood flew off on the top drivers fender. Not perfect, but not that bad either. Hood is brand new as well as the lexan front and rear windows. Side windows are still glass with working cranks.
Engine is new with four passes on it. 440Source 512 w/light weight crank option based 400 low deck with 10.8:1 and Indy EZ1 heads. Ran 9.70 with a 440/512 and is on pump gas with a Thumper Carb 4500 1050cfm carb.
Trans is a built 727 billet A&A drum with a carbon fiber CSR shield, A&A sprag, TransAct of Indy Trans brake full manual revers valve body. 8" convertor with a 5K stall. Car can be foot braked or launched off the two step and trans brake.
$26k for the car ready to race. Contact me here or thru e-mail for faster response. If your goal is to buy it as a roller, a 10% deposit on the $18k roller price is required before I pull anything apart.
'71 Duster Pump Gas 512LD for sale now too (6.19) (9.70 at 138.5mph)
'70 Cuda, 3rd year straight, can't enjoy it...Needs an engine or needs to go. (6.31) (9.9)
#2458817 - 02/28/18 10:22 AM Re: A Body - Cars For Sale - 1st Quarter [Re: moparts]
694406 Offline
Loc: St.Louis, MO
1971 Duster, 318, Auto. This is a running and driving car but honestly the body is a mess!!
The Good:
Rebuilt motor 2 years ago
Newer carpet
Factory V8 with bucket seats and console car. (Console is gone replaced with B&M shifter)
New Aluminum Radiator
New Rims and Tires
New Master Cylinder and front brakes.
Solid Frame and Crossmember
The Bad:
Like mentioned the body is a mess. Looks like it's been painted 3-4 times and filler everywhere!
Although she does run and drive the front end is pretty sloppy and needs attention.
314 703-1865
Edited by 694406 (02/28/18 10:25 AM)
1969 Cuda 383 Q5
1969 Cuda 340 4-spd Notch
1969 GTS Black on White 340 4-spd
#2464971 - 03/11/18 08:40 PM 1968 barracuda project [Re: littleredcoffin]
NoFrills Offline
Loc: East Brunswick New Jersey
1968 Barracuda notch
New 05 5.7 hemi xv intake 750 holley carb comp cam and springs
TTI HEADERS and exhaust 0
New keisler 5 speed manual transmission hydraulic clutch
NEW STRANGE Dana 60 3.54 sure grip caltracs and multi leaf
New magnumforce k frame manual rack and sway bar
Willwood disks front and rear
Redone black buckets and rear bench new door panels
Redone rally dash with tach and volt gauge
Rechromed gauge panel
Restored grills
Rechromed bumpers
New tail lights
New wiring harness
New weather striping and window gaskets
Body was completely striped now in epoxy prime original new Mexico car new pass side quarter panel glass hood with tear drop scoop
Car needs body work not rust repair and paint wiring and reassembly
Missing trunk trim glove box door and heater controls
CAR runs and drives steers and stops clean clear nj title in my name $12000 pm me email address will send pics
#2467215 - 03/16/18 02:45 AM Re: A Body - Cars For Sale - 1st Quarter [Re: moparts]
J. Hammer Offline
Loc: Memphis,TN
1975 Dart for sale,good race car project. No engine or transmission. The interior is mostly missing. 2400.00 contact me with any questions.
#2467511 - 03/16/18 07:40 PM Re: A Body - Cars For Sale - 1st Quarter [Re: moparts]
72Swinger Offline
Loc: Nebraska
1972 Dodge Dart Swinger
Built stroked 6.1 Hemi, Goldbox EFI
Viper 6spd, dual disc, pistol grip
Strange S-60 4.10 gears, 35 spline Big Ford bearing hybrid ends
14" SRT front rotors/ Viper calipers, 11.75" 2 piece rear rotors and Wilwood sliders in back
Factory welded K frame,Borgeson steering box, 1.18 FF t-bars, Hotchkis front swaybar, Hellwig adjustable rear bar with custom heims and modified Hotchkis rear leaf springs.
18x9 275/35/18 front 18x12 335/30/18 rear wheel/tire setup
1.75x.120 tube cage built in the spirit of road racing but street comfort
full interior with headliner, Speedhut gauges, carbon fiber look insert.
B5 blue, glass lift off hood, front spoiler, restored grille.
Must sell due to life changes, car is well sorted out and is akin to a modern Supercar. It goes, turns and stops unbelievably well. Car is not perfect and I have priced it to reflect that.
Asking $30,000
email for more info and pics
Mopar to the bone!!!
#2467744 - 03/17/18 12:52 PM Re: A Body - Cars For Sale - 1st Quarter [Re: moparts]
moparmarkman Offline
Loc: Minnesota
Original h-code car blue car white top and side stripe, also rear tail panel white dart sport stripe, blue interior, auto on the column. Has factory fresh air hood with scoop and black out treatment. Have fresh air air cleaner also. Has small rear end not sure of gears,it is not a posi. Power steering and power disc brake's. Fresh from ND, has vin tag, fender tag and build sheet, very solid car, missing motor, tranny and drive shaft and tranny cross member. maybe partial trade, will consider all, am open to negotiations, e-mail questions, and your trade, or a phone number, 3000 obo, Thank's for looking. Located in southern Mn.
Mopar Thanks Moparts, can email pictures
Edited by moparmarkman (03/17/18 01:03 PM)
#2468738 - Yesterday at 05:54 PM Re: A Body - Cars For Sale - 1st Quarter [Re: moparts]
hemigod426 Offline
Real deal 383 mag four speed 1968 barracuda fast back car. Been off the road and in storage since 1980.nice dash with thumbwheel radio all numbers matching car with original vin and fender tag in place.super solid car mint frames-floors-rockers-wheel houses-rear valance all rust free.42k original miles.factory maroon car with black bench seat. car is apart,90% complete needs easy resto, comes with new big bolt wilwood front disc brake kit,big bolt rear axles,new gas tank,new front bumper,new dash pad ect serious only. will only take 426 hemi parts in trade $14,999 b/o email
Edited by hemigod426 (Yesterday at 06:09 PM)
Page 2 of 2 < 1 2
25,202 Registered Members
187,678 Topics
by charles6970
03/20/18 01:25 AM
a flip ? or to much work
by theraif
03/20/18 12:40 AM
17" Front Runners
by ozymaxwedge
03/20/18 12:40 AM
Header Identification
by R/T1968R/T
03/19/18 10:11 PM
