Re: Can anyone confidently identify this noise? A833 4 speed
[Re: Cab_Burge]
#2460751
03/04/18 06:19 AM
03/04/18 06:19 AM
Posts: 96,649 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
I'm just guessing like everyone else. It's like a puzzle, enough people guess, someone will get it done/guess it.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: ]
#2460827
03/04/18 12:28 PM
03/04/18 12:28 PM
Posts: 3,103 Phila Pa
scatpacktom
Phila Pa
Its not good when your driveshaft turns into a guitar string
[Re: moparpoolman]
#2462437
03/07/18 06:06 AM
03/07/18 06:06 AM
moparedtn
moparedtn
here are some thoughts, I would double over all nuts and bolts in the general area, could possibly be trans mount cross member bolts. I would definitely run it with the axle tubes on jackstands and wheel chocks in the front and back of the front tires, WITH THE CAR POINTING OUT OF THE GARAGE with nothing in front of it, to see if noise is there with no road vibration. When the noise is present You might want to step on the clutch and turn the ignition off to see if noise is still there with engine off. If you decide to take the speedo gear out you could probably jack the back of the car as high as you can get it to minimize loss of oil. While in there you should be able to see / poke at the vent baffle tin that is in there to see if its loose. We've done the jackstands under the rear axle bit already; I "drove" the car that way while a friend bravely got down and watched from the side, but the car didn't make the noise on those stands. He reported that the driveshaft looked remarkably smooth as I wound up buzzing the car all the way up to 70mph. Made me nervous, I can tell you, even though we used 4 jackstands under the axle. It only occurred to me later afterwards that the noise only starts after the car has been driven over 5 miles or so, so I reckon things have to warm up somewhat before the racket appears. I've also already done the speedo pinion removal rhing; it looked perfect when I took it out (and yes, considerable fluid is drained when you do this that has to be returned). Further, the speedometer itself is one of the smoothest operating ones I've ever seen in an old car; GPS confirms I've got the right speedo pinion, too. I tried speedo pinion in, out, cable on, cable off. Nope. When weather permits, I'm going to get a local shops' owner to go for a ride with me so he can hear it. He specializes in Mopars and has restored several. If he can't come up with anything, I reckon I'll be left with little recourse but to swap out the transmission. :-(
[Re: ]
#2462438
03/07/18 06:14 AM
03/07/18 06:14 AM
amxautox
Drive it 5 plus miles, then put it on the jack stands while warm and try it.
Tom
author unknown
[Re: ]
#2464960
03/11/18 10:14 PM
03/11/18 10:14 PM
moparedtn
moparedtn
I have no update on this, sadly. Weather went to crap and so did work demands, not to mention I wound up spending considerable time working on both the late-model hemi critters around here ('04 Ram and '12 Charger R/T). Nothing other that what wound up being routine stuff, but have you ever changed the plugs in a hemi Ram? I've done it to this one since new, but this was the last time I'll ever do it - my rearranged and scarred innards won't take it anymore. Cancer is a [censored], especially 3 times. Someone else can do it next time.
Plan now is when the weather gets dry and warm enough to allow it, I'm going to take it by a local fellow who owns a repair shop to have a listen. He's a Mopar guy and has restored some in the past. We'll see what he thinks in person.
[Re: 71birdJ68]
#2465029
03/12/18 12:22 AM
03/12/18 12:22 AM
moparedtn
moparedtn
Who you taking it to, if I may ask? Chris Britton, but I'm not concrete on him touching the car. Did you have a suggestion?
[Re: 71birdJ68]
#2466785
03/15/18 08:21 AM
03/15/18 08:21 AM
moparedtn
moparedtn
Two guys actually, Kenny Drinnon here in town, he does mechanical stuff that I can't, and Bob Mayers in Greenville, he owner Performance Auto, he does excellent engine work, and does stuff like this at home on the weekends. I appreciate the advice. Mechanically, I can do pretty much anything so I don't typically let others work on my vehicles (short of factory recalls, of course). Engine-wise, I'm pretty good to go right now. I guess I'm saying I can fix whatever this is - but I need to figure out just exactly what it is. Thanks!
[Re: ]
#2468799
03/19/18 10:10 PM
03/19/18 10:10 PM
moparedtn
moparedtn
Well, an update of sorts...
Weather has been downright New England-ish the last couple weeks and we have still more to come apparently. Anyways, I seized on a few hour window of opportunity today and ran the car over to the shop. Fellow took a ride with me, heard the noise clear as day - and looked at me and said "I've never heard that before in my life". I thought -------- He went through all I had done and came up with the conclusion that, based on what he was feeling/hearing in person, it could only be a bearing. Reckon I concur at this point - the noise is getting worse with more driving and the gear lube I drained the other day to remove the speedo pinion didn't look so great, adding credence to the bearing theory.
Thought process quickly moved from there, past trying to fix this one (which would no doubt turn into a full blown rebuild quickly) to ok, guess I'll have to fetch another transmission - and if I go there, it won't be just any transmission. It best come from a known good source and either have a warranty (hello, Passon or Brewer's) - or come from someone I seriously trust to get it from. Only going to do this once. Really don't have the patience - or yes, time - to fool around with this for long.
Oh, and the real shocker of the day - he doesn't want to do the swap, either. He tells me this as I make note of the '71 'Cuda on one lift and the full tube frame 'Cuda in another bay. He says he only works on his own Mopars now, not anyone else's - and "modern" stuff for customers. Says something else could go wrong during the job and he doesn't want that grief. Whatever... I got a couple other places in town that didn't bat an eye telling me they're not afraid of the job and they shouldn't be. The one literally within a mile of my place says "yeah, bring it by or I can come give it a nice ride on the rollback. $100." As in he wants $100 to do the job. Even expects me to be there when he does to "keep him straight". I think I have a new buddy. :-)
Ok....Brewer's or Passon? I'd love to do an 18 spline, but my brand new clutch setup is for a 23 spline 11".
[Re: Cab_Burge]
#2468983
03/20/18 10:15 AM
03/20/18 10:15 AM
moparedtn
moparedtn
I'm typically the same way, but not with transmissions. I've had them apart just to see how, but the interest ended right there. :-) I don't have the patience (or the luxury of time) to rebuild this one, especially since it was a freebie to begin with and nothing special. I'm not sure the noise is, well, anything specifically - I've just arrived at that conclusion by eliminating what it couldn't be - and since nobody has come up with anything else better, it'll get yanked and replaced, to be sorted out by someone else later maybe. Question stands - who does the better rebuild, Brewer's or Passon?
[Re: moparpoolman]
#2469155
03/20/18 02:57 PM
03/20/18 02:57 PM
moparedtn
moparedtn
I appreciate all the help, my friend, but... Decision made, order placed. Came down to a factor of time. Brewer's is months behind in orders and won't have a unit available until the end of May (!). Dan was honest in telling me that and I appreciate it. Had a nice chat with Jamie at Passon just a bit ago. We spoke on several topics and he shed some light on things I had been wondering about in Mopar world in general. Dude sounds tired but that's a good thing. He also sounds honest. Three weeks on his time frame. I placed an order with him on the spot, including a roller type input bearing to install in place of the bushing. Wife is fussing. She'll get over it. He recommended going back with the late 60's 23 spline unit since I still have that crossmember, even though he advised that the early 70's B/E unit I have now is no different mechanically, just on shifter mounting options and I have the modified crossmember for that as well, which I'll probably be selling. Now the wait begins....
[Re: ]
#2469212
03/20/18 04:21 PM
03/20/18 04:21 PM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
I wouldn't hesitate to get one form either of them. If you want to go 18 spline you just need another disc. But be warned a rebuilt isn't going to be cheap .
[Re: JohnRR]
#2469361
03/20/18 08:46 PM
03/20/18 08:46 PM
moparedtn
moparedtn
I wouldn't hesitate to get one form either of them. If you want to go 18 spline you just need another disc. But be warned a rebuilt isn't going to be cheap . Thanks. Yes, my having a new 23 spline clutch setup (an expensive one at that) is why another 23 spline transmission was ordered....and yes, they aren't cheap. Nonetheless, it's already bought.
