Now the pulleys dont line up!!!!! #2458570
02/27/18 09:18 PM
02/27/18 09:18 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
Got the E86 440 cop motor running. Had to get a water pump housing off ebay with the same casting number. This is off an AC car with most of the front brackets missing. I have a 4, 3 and 2 pulley set for the crank and a shallow single, deep single and deep double at the water pump. Have a 440 source PS bracket which has the belt rubbing the pump bolt as well as a 440 source alternator bracket. If there is such a think as a non AC 440 with an alternator and power steering pump, COULD I GET A PICTURE?????? Seems the PS pump needs to go forward, it is a Saginaw. The water pump housing thermostat bolts are NOT parallel with the radiator. Maybe I need a different housing. Thanks Phish
CALMED THE QUAKE!!!(AGAIN!)
Re: Now the pulleys dont line up!!!!! [Re: Spyphish] #2458598
02/27/18 10:09 PM
02/27/18 10:09 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i'd cut you a really good deal on a serpentine belt kit so you can avoid this mess.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Now the pulleys dont line up!!!!! [Re: Spyphish] #2458603
02/27/18 10:19 PM
02/27/18 10:19 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Take a look. I did a mock up. I think you need the fan tensioner. One groove for power steering, one for fan and two for alternator/AC (use one only for non AC) Three separate belts!!!
Re: Now the pulleys dont line up!!!!! [Re: Jerry] #2458654
02/28/18 12:33 AM
02/28/18 12:33 AM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
Call me Wed. 337-499-44 three five Thanks
Re: Now the pulleys dont line up!!!!! [Re: Spyphish] #2458692
02/28/18 01:59 AM
02/28/18 01:59 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
This is a stock 440 with NO A/C and power steering. My OWN car:
Re: Now the pulleys dont line up!!!!! [Re: Spyphish] #2458694
02/28/18 02:00 AM
02/28/18 02:00 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
You need the triangle bracket for the upper alternator bracket along with what appears to be a slightly curved "strap" for the lower alternator bracket. The lower bracket you showed is not correct for a NON A/C setup.
Mine uses a 2 groove crank pulley, a single groove W/P and single for the P/S pump. The alternator is 2 groove only because it was the parts store had in stock.
I am actually switching to A/C and dealing with all of the multiple pulley combinations the factory used!
Re: Now the pulleys dont line up!!!!! [Re: Spyphish] #2458697
02/28/18 02:05 AM
02/28/18 02:05 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
More:
Re: Now the pulleys dont line up!!!!! [Re: Spyphish] #2458700
02/28/18 02:09 AM
02/28/18 02:09 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
My experience is that all of the water pump housings have the same attachment points for the brackets whether the housing is iron or aluminum, left hand lower hose or right hand.
If you need a bracket or pulley, I may have some spares. The set I am removing is going to be set aside in case I need it again.
Re: Now the pulleys dont line up!!!!! [Re: Spyphish] #2458736
02/28/18 09:02 AM
02/28/18 09:02 AM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
Those pics sure help. I have to get the PS pump forward some how. It was on a 318, maybe the pulley to pump distance is different. Pump mounts fine on 440 source stuff but pulley would have belt on back grove which rubs the water pump. May just find a complete BB PS assembly. Phish
Yep, just found a complete Saginaw setup including brackets and the cop PS cooler for 90 bucks. So, we will see if those brackets move it forward. Thanks
Re: Now the pulleys dont line up!!!!! [Re: Spyphish] #2458749
02/28/18 10:55 AM
02/28/18 10:55 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Here is a complete 73 440 pulled out of a Newport that I have for sale. I can take more pics if you need them.
JB Rhinehart, Realist
A-Body's RULE!
Re: Now the pulleys dont line up!!!!! [Re: Spyphish] #2458773
02/28/18 11:55 AM
02/28/18 11:55 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Yes, there are many different pulley & bracket configurations depending on A/C vs, non A/C cars. My red 70' Charger is a factory A/C & power steering car & still has all of the correct brackets & pulleys.
I remember eliminating the A/C off of another car before & it took other brackets & pulleys to make it all work again because the A/C compressor spins with the alternator.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Now the pulleys dont line up!!!!! [Re: Spyphish] #2461119
03/04/18 08:44 PM
03/04/18 08:44 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
OK I have the PS pump where it needs to go. What I need now is a 2 groove 6" or slightly less, 2.5" deep water pump pulley. A six pack car here has one on it. I may have to take it off to get a number. Ebay did not have a 2.5 deep. If you have one extra, let me know. Thanks Stephen 337-499-44 three five
Re: Now the pulleys dont line up!!!!! [Re: Spyphish] #2462990
03/08/18 08:57 AM
03/08/18 08:57 AM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
OK this solved the alignment problem but still missing a water pump to PS pump bracket. This is a Saginaw pump with cooler IE police package. Anyone have a picture of a complete setup? Or an extra correct bracket.Thanks
Note the adjust slot and 1/2 inch ratchet hole are on the pump bracket. Missing is a triangle piece I would think.
Re: Now the pulleys dont line up!!!!! [Re: Spyphish] #2463322
03/08/18 08:54 PM
03/08/18 08:54 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
bolt the pump/bracket right to the water pump housing not the block
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
