02 dodge durango 4x4 answer #903203
01/13/11 01:50 AM
01/13/11 01:50 AM
ill
dennismopar73 Offline OP
ill
i have 02 durango 4x4 a wheel drive
drove yesterday with no issues
got in today drove to town ,
smelled like burnt gear oil , no drive
after getting fuel
put turn switch to 4 wheel cgoes int o gear ,
yeah it goe,, no problem shifting
but has no front drive ,, just rear drive
put back to all wheel no go
WHAT HAS HAPPENED HERE???
Re: 02 dodge durango 4x4 answer [Re: dennismopar73] #903204
01/13/11 10:08 AM
01/13/11 10:08 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I would get under there and see what's leaking first of all, if you smell the gear oils unique odor.
Re: 02 dodge durango 4x4 answer [Re: buildanother] #2457547
02/25/18 10:11 PM
02/25/18 10:11 PM
Pa.
10 secondman Offline
Pa.
sounds like trans quit , ,smell transfluid , smell like burnt , oil , then have trans problem -oil should have a clear to reddish color to it ,if good , -good luck , hope this helps
Re: 02 dodge durango 4x4 answer [Re: dennismopar73] #2458454
02/27/18 04:25 PM
02/27/18 04:25 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
with the front driveshaft out you have to have it in 4 lock to go anywhere so it sounds like you have somehow duplicated that issue, could be t-case, front driveshaft, or front diff.
