Page 4 of 4 < 1 2 3 4
#2448455 - 02/08/18 09:48 AM Re: 70 340 SIX PACK 727 TRANSMISSION T/A CHALLENGER ,AAR CUDA [Re: moparts]
BlakDak71 Offline
Loc: Michigan
Edited by BlakDak71 (02/13/18 06:42 AM)
#2451944 - 02/14/18 09:45 PM Re: Mopar Transmission For Sale - 1st Quarter [Re: moparts]
dsd70bee Offline
Loc: oak park, il.
Clutch pedal assembly from a 1973 or 1974 B-body, will also work in a 1971 or 1972 B-body, nice used condition $400.00 (708)288-2879 Scott
#2452251 - 02/15/18 03:23 PM Re: Mopar Transmission For Sale - 1st Quarter [Re: moparts]
gtea1901 Offline
used but in great shape 904 trans 2.74/1.54 gear set with lightened sun shell. $175.00
Call Denny (386) 957-3879 shop (717) 676-3349 cell
#2457803 - 02/26/18 08:58 AM 1970 B&E-Body 18 Spline Hemi 4 Speed Transmission for sale [Re: gdmusclecar]
ScottSmith_Harms Offline
Mr Wizzard
Loc: Spokane Washington
Fresh rebuild from Brewers Transmissions - 1970 and up B&E-Body 18 Spline Hemi 4 Speed Transmission, VIN Sequence pad stamping: 0G146336 2999 0401.
Still in the shipping box from Brewers, no shortcuts, Still in raw cast iron finish as shown, no paint so perfect for an OE detail job. beautiful transmission ready to bolt in. $2,500.00 plus shipping. 801-940-2689 - Located in Spokane Washington.
#2458155 - 02/26/18 08:21 PM Re: 1956 Chrysler New Yorker [Re: moparts]
36PLYM Offline
Loc: Lithonia, Ga
Chrysler New Yorker auto trans from 354 Hemi with torque converter. Local pickup, $200
Edited by 36PLYM (02/26/18 08:23 PM)
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
#2458167 - 02/26/18 08:36 PM 727, 904, 518 transmissions for sale. [Re: kenworth_goose]
kenworth_goose Offline
Loc: ky.
727, 904, 518 transmissions for sale. 100.00 each for cores.
#2458326 - 02/27/18 09:48 AM Power Wagon automatic transmission tailshaft. [Re: kenworth_goose]
Genuinejed Offline
Loc: Spokane,WA
Truck extension housing and output shaft assembly from an early 70s big block power wagon. Includes speedo plug and bolt on yoke for small U joint. (2 1/8 inside).
$75 plus shipping
1968 Plymouth road runner 1968 Dodge Coronet 500 64 D200 Good, Fast, Cheap. Pick Two.
#2461630 - 03/05/18 04:28 PM Re: Turbo Action Valve Body [Re: RalphsRapidTrnst]
MIKEG1955 Offline
Please contact the seller via pm or email. This is not a discussion forum.
Edited by tboomer (03/06/18 05:07 PM)
Edit Reason: not a discussion board
#2463398 - 03/08/18 07:39 PM Re: Mopar Transmission For Sale - 1st Quarter [Re: moparts]
5wndwcpe Offline
Loc: Southeast PA
Centerforce II pressure plate - nearly new condition part # CFT361800
This was mocked up on a motor but never run in the car. Showing a bit of shelf wear as well but no damage.
$175 plus the ride.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1968 Satellite sedan
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
1974 Harley Davidson FLH
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
#2465318 - 03/12/18 04:04 PM 1968 Hemi 18 Spline transmission [Re: 5wndwcpe]
shamefulcuda Offline
Loc: California
Trans and shifter is SOLD
Edited by shamefulcuda (03/14/18 07:23 PM)
#2466875 - 03/15/18 11:13 AM Re: Mopar Transmission For Sale - 1st Quarter [Re: moparts]
Mopar Stan Offline
Loc: PA, USA
Mopar 904 small block street/strip trans just rebuilt later case has modified stock 5-clutch drum with red clutches /steels,special spring to stop it from unwinding on top end,A&A wide 1.750 solid red racing front kd band,4.2 lever strut,rear clutch 4-red racing clutches//steels,rear drum,sun gear,rear clutch lightened,4-pinion frt/rear steel planets,A&A double wrap red racing rev band,deep steel pan,new pump gears,vent blocked moved to rear,Turbo Action RVMVB with A&A special spring to increase line pressure,oil mods to case/ internals/converter access in case.
$1,350 free shipping pm for details/pics
#2466892 - 03/15/18 11:39 AM Re: Mopar Transmission For Sale - 1st Quarter [Re: moparts]
Mopar Stan Offline
Loc: PA, USA
727 Big Block racing trans A&A transbrake with low band apply,Billet steel drum with billet retainer and 15-1.4 springs,A&A Wide Solid Red Racing KD Band,5-thick red racing clutches/steels,frt drum 4-red racing clutches/steels rear clutch,with factory stock HP input shaft,steel spacer ring and modified piston /spring,lightened sun gear,rear drum.rear clutch,rollerized rear support,alum spacer in place of gov housing,A&A red racing rev band,bolt in sprag,deep steel pan,4-pinion alum planet frt/rear,76-up later intermediate shaft,new pump gears,babbit front pump bushing,vent blocked moved to rear,billet rear servo,acc.blocked,70 frt servo with %65 springs,modified case for converter access,oil mods to internals/case,teflon sealing rings.
$2,950 free shipping pm for details/pics
#2467738 - 03/17/18 12:14 PM Re: Mopar Transmission For Sale - 1st Quarter [Re: moparts]
RapidusMaximus Offline
Loc: Haslet, Texas
Amost everything you need to convert an A body to 4 speed, what you see in the pics is all I have, missing is some of the shift lever parts and of course all of the clutch, flywheel and related hardware, all of this came with a 67 Dart project I bought and am converting to auto (I need a pedal assy if your converting), the trans is a 23 spline 833 and it turns freely but I do not know the internal condition, feel free to ask questions or for more detailed pics, price is 1000.00 for everything obo pm me here or email alilblacktruckatgmaildotcom, prefer pick up but will ship at buyers expense, thanks!
1968 Plymouth GTX 440 4 Speed Dana
1967 Small block Dart under construction
1974 Dodge P/U Long Bed Stepside 318 Auto
1975 Jeep CJ5
1994 Turbocharged Fuel Injected Dakota (for sale)
2016 Dodge Ram Hemi 1500
#2467750 - 03/17/18 12:58 PM Re: Mopar Transmission For Sale - 1st Quarter [Re: moparts]
CRT Offline
Loc: Cedar Lake IN
A500 & 518 ( includes all RHs & all REs ) billet trans brake valve body & billet reverse manual valve body in NON lock up with a shift pattern of PR1234 are on sale $200 bucks off now until March 31st.
Cope Racing Transmissions
#2468262 - Yesterday at 05:51 PM 833 od 4 speed, 75-77 [Re: moparts]
Loc: ky.
833 OD 4 speed transmission, it has the same rear piece as the 70 up E body and B bodies. The tailshaft is worth 200.00 alone. This is a good working trans. I want 400.00 for it obo. Cast iron case, aluminum side cover.
25,200 Registered Members
187,645 Topics
Bucket seat questions??
by busboy
03/19/18 09:52 AM
1985 Diplomat Cop Car, with cop acc, $1500 NorCal
by NV69B7RR
03/19/18 09:52 AM
Different demon in the 9s
by toplescuda
03/19/18 09:49 AM
Stay Aligned With RMS’ New Toe and Digital Angle Gauges
by Rustymuscle
03/19/18 09:42 AM
