Advice on 46RE and 46RH rebuilds #2457712
02/26/18 02:25 AM
02/26/18 02:25 AM
Atlanta, GA
mgoblue9798 Offline OP
Atlanta, GA
One is in my 2002 Dodge Ram Van 1500, has 185,000 trans has flare out between 2/3 guessing it is the lip seal problem.
Other is from 1993 Dakota going to retrofit to my D100 Ext Cab long bed that will be used for towing occasionally. Was running when parked but fluid and probably clutches are burnt.
I have built several 727s but these will be my first with O/D trans.
Any advice on parts, upgrades, things to look out for in hard parts, etc is welcome. I know about the special tools for the O/D and have them on the way. I plan to keep both of these vehicles for as long as I live so I don't mind putting money into these. Would like to do extra clutches, towing shift kit, good bands, etc as both vehicles will tow at least my boat and probably cars occasionally. One will be behind a 408 stroker and the other behind a 440. Both will have around 475 to 500 pound feet of torque.
Also who makes good a/m converter with upgraded lock up for these?
Thanks in advance for the help.
Re: Advice on 46RE and 46RH rebuilds [Re: mgoblue9798] #2457737
02/26/18 03:44 AM
02/26/18 03:44 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
get a transgo shift programing kit !
Re: Advice on 46RE and 46RH rebuilds [Re: mgoblue9798] #2457866
02/26/18 02:15 PM
02/26/18 02:15 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted By mgoblue9798
...One will be behind a 408 stroker and the other behind a 440....
How are you going to get a 4RH to bolt up to a 440?
Re: Advice on 46RE and 46RH rebuilds [Re: 6PakBee] #2458018
02/26/18 07:24 PM
02/26/18 07:24 PM
Atlanta, GA
Atlanta, GA
can be done with a JW Ultrabell or with a bellhousing adapter, I have the adapter
Re: Advice on 46RE and 46RH rebuilds [Re: mgoblue9798] #2458062
02/26/18 08:44 PM
02/26/18 08:44 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I'm doing my 01 Van trans this week. I would take the overdrive part to a trans shop to release the spring, install new clutches then re-install the spring aligning the splines with their line up shaft.
There is an updated pressure solenoid you should get too. I'm sure more of the experts will chime in on this.
Mine had nothing in the pan, but the magnet was about the size of a donut, a full 1/2 inch of very fine metal particals and what looked like moly lube. Haven't got it apart yet. I bought the factory complete overhaul kit less bands. Don't go cheaply on this.
Re: Advice on 46RE and 46RH rebuilds [Re: mgoblue9798] #2458125
02/26/18 10:39 PM
02/26/18 10:39 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
You won't need to do a lot to the trannies to get them to hold the torque you are planning to throw at them.
I would suggest that you take the OD units to a shop familiar with them. Their experience alone would be worth the price of admission.
A&A Transmissions is the go-to source for parts and info. PATC is another good one.
Good parts, good advice, good line pressure, a good valve body kit and you're good to go.
Lenny at Ultimate Converter fixed my PTC problems, so I would recommend a conference with him on the converter..
Master, again and still
Re: Advice on 46RE and 46RH rebuilds [Re: DaveRS23] #2458235
02/27/18 02:16 AM
02/27/18 02:16 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
when i overhauled the A500 in my dakota i used a hydraulic press to compress the od spring,did i do it right?,im not sure,but it works perfect
my ladder of success is missing some rungs
Re: Advice on 46RE and 46RH rebuilds [Re: mgoblue9798] #2458316
02/27/18 12:31 PM
02/27/18 12:31 PM
moparx Offline
moparx  Offline
what adapter did you use ?
beer
Re: Advice on 46RE and 46RH rebuilds [Re: mgoblue9798] #2458399
02/27/18 02:31 PM
02/27/18 02:31 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
As you mentioned, need the OD alignment Tool and the OD Spring Compressor tool to use in a press.
I see PACT sells a stiffer OD spring. Not sure how much difference it would make? All I have done was stock type rebuild with shift kit.
Re: Advice on 46RE and 46RH rebuilds [Re: 451Mopar] #2458459
02/27/18 04:30 PM
02/27/18 04:30 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I used that heavier OD spring in the tranny behind my 540 Hemi. It was kinda expensive for a spring. But if I understand the OD correctly, that spring holds the clutch pack that all 3 forward gears go through. So, I figured it couldn't hurt.
Re: Advice on 46RE and 46RH rebuilds [Re: DaveRS23] #2458467
02/27/18 04:57 PM
02/27/18 04:57 PM
Guitar Jones Offline
I wonder about it's worth as well because when that spring is compressed all the pressure rides on a torrington bearing that has been known to fail even in stock applications.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Advice on 46RE and 46RH rebuilds [Re: Guitar Jones] #2458485
02/27/18 05:24 PM
02/27/18 05:24 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have heard about OE bearing failures, too. Seemed mostly in high mileage units.
I asked around some but did not find anyone that has installed one of these heavier ones and then had problems.
Besides, I doubt that I will ever put 10,000 miles on this combo. Maybe it will last that long.
Re: Advice on 46RE and 46RH rebuilds [Re: Guitar Jones] #2458489
02/27/18 05:41 PM
02/27/18 05:41 PM
Atlanta, GA
Atlanta, GA
Wasn't there a mid production revision of this bearing? Any idea what year it changed, or if there is an upgrade availabe?
Re: Advice on 46RE and 46RH rebuilds [Re: moparx] #2458491
02/27/18 05:44 PM
02/27/18 05:44 PM
Atlanta, GA
Atlanta, GA
smr transmission, I would post a link but the website isn't working.
I have not installed it yet or even checked fitment so I really can't comment about the product.
Re: Advice on 46RE and 46RH rebuilds [Re: mgoblue9798] #2458542
02/27/18 07:33 PM
02/27/18 07:33 PM
A727Tflite Offline
A727Tflite  Offline
The early overdrives had a powder metal spring seat - that was changed to a forged part early in the program - plus this new bearing seat had lube grooves added to it.
Keep ATF + 4 level fluid in it and it will last you hundreds of thousands of miles. You will break the wavy snap ring before you fail the bearing with this new seat.
A higher spring rate is a waste of time in a race car or passenger car.
Re: Advice on 46RE and 46RH rebuilds [Re: A727Tflite] #2459150
02/28/18 11:41 PM
02/28/18 11:41 PM
Atlanta, GA
Atlanta, GA
Thanks Transman, I was hoping you would chime in.
I Knew I had read something about it had changed. I have a 518 I bought directly from Mopar Performance in 1994. It is a non lockup trans. I am guessing it is probably an early run trans. Will the new seat interchange? Is the bearing itself the same?
If you don't mind me picking your brain sir, how would you build these trannys if they were going into your own ride? I plan to get the sonnax kit to make them oil in park. I have read something about drilling the output shaft to get more oil to the o/d unit?
What a/m parts or upgrades would you recommend?
Re: Advice on 46RE and 46RH rebuilds [Re: mgoblue9798] #2459333
03/01/18 12:07 PM
03/01/18 12:07 PM
A727Tflite Offline
A727Tflite  Offline
Mgoblue9798 - let's start with the PK number off the pan rail.
Let's see what it was built with.
Drilling the oil holes in the intermediate or output shaft isn't necessary.
Adding the Sonnax regulator valve is a good addition to keep the converter charged in park (lube flow).
Re: Advice on 46RE and 46RH rebuilds [Re: mgoblue9798] #2460283
03/03/18 01:17 AM
03/03/18 01:17 AM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
I will be rebuilding my 46rh as well for my truck.
Will the convertor work from an older lockup, non od 904?
Re: Advice on 46RE and 46RH rebuilds [Re: mgoblue9798] #2460407
03/03/18 11:31 AM
03/03/18 11:31 AM
A727Tflite Offline
A727Tflite  Offline
904 and 727 converters are not interchangeable.
Lockup and non-lockup are not either even in the same family - there is one spline difference between the two to prevent that in service.
